When I'm using my laptops built-in mobile broadband modem, skype cannot connect.
Additional symptom: After signing out of skype, I cannot sign in again. (Sign in works fine on wifi)
Everything else (internet connection from browser, dropbox, etc.) connects without problems.
Details:
  • Ubuntu 14.04
  • Thinkpad T440
  • Modem: Sierra Wireless EM7345 4G LTE
When using wifi, skype connects fine.
When using the same sim-card, inserted into a mobile wifi box like huawei E5776, skype can also connect without problems. (This is via wifi to the huawei box, and via gsm from there).
This indicates:
a) that it is not my ISP blocking anything. (also, according to their technical support they are not blocking).
b) that the problem is related to the use of the modem connection from ubuntu. It could be a problem with the modem (firmware?), or with ubuntu/modemmanager/networkmanager.
I suspect this has something to do with ubuntu and/or skype treating the wireless broadband connection differently from a wifi connection. Perhaps it has something to do with dialout, with 'metered connection', etc.
I checked the permissions on the modem device, only root had access to the device. The device did not have the dialout group, as described in this bug: https://bugs.launchpad.net/ubuntu/+source/udev/+bug/1032865
I added the device to the dialout group as described in the bug. After the fix:
crw-rw---- 1 root dialout 180, 0 Aug 26 11:09 cdc-wdm0
I also added my own user (the user running skype) to the dialout group, as described here: Changing permissions on serial port
BUT this did not solve the problem.
Any hints?
sunew
  • 101
5 Answers5
I found a blog that say that the stock drivers on your modem (Sierra Wireless EM7345 4G LTE) has some bugs in it, please read this link.
Also, did you try connecting Skype using a HTTP Proxy? Check the following link and give it a try...
araghuteja
  • 294
change below settings in 4G modom
tools -> Options -> select connection type NDIS and click OK, now click connect. now skype will work
this is working in AIRTEL 4G dongle
I also use the Sierra Wireless, the only time I had this issue was when bandwidth was poor over 4G and it was actually more like 2G. Have you run a speed test when this happens? Also try disabling all other adapters then connect via 4G Network.
A workaround for getting acces to using skype when on my mobile broadband connection:
Use the skype web client, https://web.skype.com/. Unfortunately video / voice calls do not work (yet) on linux - only text based chat.
sunew
  • 101
With the latest kernel update Linux X1 3.16.0-55-generic #74~14.04.1-Ubuntu Skype is now working on 3G. Lenovo X1 Carbon 3rd gen.
Zlatko
