I am running ubuntu 15.04 on a Lenovo yoga 3 pro I'm having trouble installing the banshee media player. When I attempt to install via the Software Center, I get the following notification:
banshee: Depends: libglib2.0-0 (>= 2.44.1) but 2.44.0-1ubuntu3 is to be installed
Depends: libgtk2.0-0 (>= 2.24.0) but 2.24.27-0ubuntu1 is to be installed
Depends: libsoup-gnome2.4-1 (>= 2.27.4) but 2.49.92-1 is to be installed
Depends: libsoup2.4-1 (>= 2.26.1) but 2.49.92-1 is to be installed
Depends: libx11-6 (>= 2:1.6.0) but 2:1.6.2-2ubuntu2 is to be installed
Depends: mono-runtime (>= 3.0~) but 3.2.8+dfsg-4ubuntu4 is to be installed
Depends: libc0.1 (>= 2.21) but it is not going to be installed
Depends: libgconf2.0-cil (>= 2.24.0) but 2.24.2-3 is to be installed
Depends: libgdk-pixbuf2.0-0 (>= 2.31.3) but 2.31.3-1 is to be installed
Depends: libglib2.0-cil (>= 2.12.10-1ubuntu1) but 2.12.10-5.1 is to be installed
Depends: libgtk2.0-cil (>= 2.12.10-1ubuntu1) but 2.12.10-5.1 is to be installed
Depends: libmono-cairo4.0-cil (>= 3.2.1) but 3.2.8+dfsg-4ubuntu4 is to be installed
Depends: libmono-corlib4.5-cil (>= 3.2.8) but 3.2.8+dfsg-4ubuntu4 is to be installed
Depends: libmono-posix4.0-cil (>= 3.2.3) but 3.2.8+dfsg-4ubuntu4 is to be installed
Depends: libmono-system-core4.0-cil (>= 3.2.8) but 3.2.8+dfsg-4ubuntu4 is to be installed
Depends: libmono-system-xml4.0-cil (>= 3.2.1) but 3.2.8+dfsg-4ubuntu4 is to be installed
Depends: libmono-system4.0-cil (>= 3.2.8) but 3.2.8+dfsg-4ubuntu4 is to be installed
Depends: gnome-icon-theme (>= 2.16) but 3.12.0-1ubuntu1 is to be installed
So I tried to install via the terminal, with this command:
sudo apt-get -f install banshee
which gave me the following output:
Reading package lists... Done
Building dependency tree
banshee : Depends: libglib2.0-0 (>= 2.44.1) but 2.44.0-1ubuntu3 is to be installed
Recommends: banshee-extension-soundmenu (= 2.9.0+really2.6.2-2ubuntu5) but it is not going to be installed
I'm still pretty new with Ubuntu, so I'd appreciate simpleton-style explanations...thank you!
I was referred to this question: How do I resolve unmet dependencies after adding a PPA? which I don't think was effective- I may not be following the directions appropriately it seems a little unrelated to me. here is my terminal history of the troubleshooting I tried from the question:
will@will-Lenovo-YOGA-3-Pro-1370:~$ sudo apt-get autoclean
[sudo] password for will:
will@will-Lenovo-YOGA-3-Pro-1370:~$ sudo apt-get -f install
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
will@will-Lenovo-YOGA-3-Pro-1370:~$ sudo apt-get -f install banshee
will@will-Lenovo-YOGA-3-Pro-1370:~$ sudo dpkg --configure -a
will@will-Lenovo-YOGA-3-Pro-1370:~$ sudo dpkg --configure -a banshee
dpkg: error: --configure --pending does not take any non-option arguments
>Type dpkg --help for help about installing and deinstalling packages [*];
Use 'apt' or 'aptitude' for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
will@will-Lenovo-YOGA-3-Pro-1370:~$ sudo apt-get -u dist-upgrade
Calculating upgrade... Done
will@will-Lenovo-YOGA-3-Pro-1370:~$ sudo apt-get clean
Reading package lists... 7%
Requested info:
will@will-Lenovo-YOGA-3-Pro-1370:~$ apt-cache policy libglib2.0-0
libglib2.0-0:
Installed: 2.44.0-1ubuntu3
Candidate: 2.44.0-1ubuntu3
Version table:
*** 2.44.0-1ubuntu3 0
500 http://us.archive.ubuntu.com/ubuntu/ vivid/main amd64 Packages
100 /var/lib/dpkg/status
will@will-Lenovo-YOGA-3-Pro-1370:~$ apt-cache policy banshee
banshee:
Installed: (none)
Candidate: 2.9.0+really2.6.2-2ubuntu5
Version table:
2.9.0+really2.6.2-2ubuntu5 0
500 http://us.archive.ubuntu.com/ubuntu/ vivid-updates/universe amd64 Packages
2.9.0+really2.6.2-2ubuntu4 0
500 http://us.archive.ubuntu.com/ubuntu/ vivid/universe amd64 Packages
