Hi my laptop crashed recently so I bought a new SSD (500gig) as well as a new operating system (ubuntu 64-bit) I have a Dell i5 laptop.i use my laptop for Photoshop, adobe after effects basicly most of adobe software. And so I need to install this OS properly so that it will function properly with my intensive adobe software. I have 6 gigs of ram .how do go about installing it and partitioning it properly without using up to much space for partitioning and to make my SSD work nicely cos its been said that'it is faster then your normal hardrive. And I previously had Windows 7
The instructions for installing Ubuntu onto an SSD are no different than for a traditional hard drive. The default partitioning recommended by the installer will be suitable.
The speed benefits of an SSD do not require special configuration of the OS.
It wasn't a main part of your question, but you are going to run into difficulties getting Photoshop and After Effects running on Ubuntu (with Wine). After Effects in particular probably won't work at all if you have version 9 or later (CS4 or later) (source).
Adobe Photoshop CS5 won't run, and Adobe Premiere Pro beyond version CS3 won't run. Other versions will run with problems or will be difficult to get working (source).
Elder Geek
  • 36,752
thomasrutter
  • 37,804
