Black screen on resume from suspend is a kernel panic caused by the wireless card (Broadcom) changing its status.
For current solution, see below...
Outdated solution 1
You can now fix the problem by applying the following patch :
wget https://launchpadlibrarian.net/196100480/0014-null-pointer-crash.patch
sudo cp 0014-null-pointer-crash.patch /usr/src/bcmwl-6.30.223.248+bdcom/patches/
Add the path of the patch file in your dkms.conf file :
sudo nano /usr/src/bcmwl-6.30.223.248+bdcom/dkms.conf
Your dkms.conf should look something like this after your changes :
PACKAGE_NAME="bcmwl"
PACKAGE_VERSION="6.30.223.248+bdcom"
CLEAN="rm -f *.*o"
BUILT_MODULE_NAME[0]="wl"
MAKE[0]="make -C $kernel_source_dir M=$dkms_tree/$PACKAGE_NAME/$PACKAGE_VERSION/build"
DEST_MODULE_LOCATION[0]="/updates"
PATCH[0]="0001-MODULE_LICENSE.patch"
PATCH[1]="0002-Makefile.patch"
PATCH[2]="0003-Make-up-for-missing-init_MUTEX.patch"
PATCH[3]="0010-change-the-network-interface-name-from-eth-to-wlan.patch"
PATCH[4]="0011-do-not-define-devinit-as-__init-in-linux-3.8-as-.patch"
PATCH[5]="0012-add-support-for-Linux-3.15.patch"
PATCH[6]="0013-gcc.patch"
PATCH[7]="0014-add-support-for-Linux-3.17.patch"
PATCH[8]="0015-add-support-for-Linux-3.18.patch"
PATCH[9]="0016-repair-make-warnings.patch"
PATCH[10]="0017-add-support-for-Linux-4.0.patch"
PATCH[11]="0014-null-pointer-crash.patch"
#PATCH_MATCH[6]="^3.[10-11]"
AUTOINSTALL="yes"
Reload the module :
sudo /usr/lib/dkms/common.postinst bcmwl 6.30.223.248+bdcom /usr/share/bcmwl x86_64 $(uname -r)
You won't have anymore black screen on resume from suspend. See here for more informations.
Outdated solution 2
A PPA including the fix has been set up by Canonical.
Simply use the repository and no need to manually apply the previous patch anymore.
sudo apt-add-repository ppa:inaddy/lp1415880
sudo apt-get update
sudo apt-get upgrade
Newest solution
There is no need to add additional PPA anymore. A fix as been released in Ubuntu repositories. Simply install the patched version by update your system :
sudo apt-get update
