I've installed PostgreSQL v9.3 (database) on Ubuntu 14.04 and I'm currently attempting to install the following:
sudo apt-get install postgresql-9.3-postgis-2.1
However I'm getting the following error:
The following packages have unmet dependencies: postgresql-9.3-postgis-2.1 : Depends: libgdal1h (>= 1.9.0) but it is not installable Depends: libgeos-c1 (>= 3.4.2) but it is not going to be installed Depends: liblwgeom-2.1.7 (>= 2.1.6) but it is not going to be installed Depends: libproj0 (>= 4.8.0-1) but it is not installable E: Unable to correct problems, you have held broken packages.
Please Note: I have already successfully installed the following:
sudo apt-get install postgresql-contrib-9.3
sudo apt-get install postgresql-9.3-postgis-2.1-scripts
How can I solve this?
Oudin
  • 201
After some additional research I found the answer via the following questions How do I resolve unmet dependencies after adding a PPA? which can be applied to this question as a solution.
In your terminal run
software-properties-gtk
Under Ubuntu Software tab, enable all the repositories
Next run
sudo apt-get update
sudo apt-get upgrade
Finally run
Worked successfully for me I hope this helps someone with the same issue install postgresql-9.3-postgis-2.1 with unmet dependencies on Ubuntu 14.04
Oudin
  • 201
I ran into a very similar problem while provisioning an Ubuntu 14.04 box with Vagrant using a configuration that used to work:
postgresql-9.3-postgis-2.1 : Depends: libgdal1h (>= 1.9.0) but it is not going to be installed
                             Depends: liblwgeom-2.1.2 (>= 2.1.2) but it is not going to be installed
It turns out there was a conflict with the official Ubuntu repository and the Postgresql.org repository and ubuntugis ppa. Not adding those repositories as sources when provisioning the box fixed the issue for me.
