I tried and failed to install gnuradio-dev a week ago, and gave up. Little did I know, apparently my botched attemps has put APT into a real bind. Installing, removing, or running dist-upgrade (or any other APT command) leaves me with dependency errors.
I opened Software Center to see if there were suggestions where, and it offered to repair. That failed, but I did finally get a useful error message:
(Reading database ... 333769 files and directories currently installed.)
Preparing to unpack .../libgnuradio-iqbalance_0.37.2-gqrx~trusty6_amd64.deb ...
Unpacking libgnuradio-iqbalance (0.37.2-gqrx~trusty6) ...
dpkg: error processing archive /var/cache/apt/archives/libgnuradio-iqbalance_0.37.2-gqrx~trusty6_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/python2.7/dist-packages/gnuradio/iqbalance/__init__.py', which is also in package gr-iqbal 0.37.1.5.d4fd4d-1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Error in function:
dpkg: dependency problems prevent configuration of gr-osmosdr:
 gr-osmosdr depends on libgnuradio-iqbalance; however:
  Package libgnuradio-iqbalance is not installed.
dpkg: error processing package gr-osmosdr (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libgnuradio-osmosdr0.1.4:amd64:
Attempting to install libgnuradio-iqbalance leaves me with this:
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 77 not upgraded.
2 not fully installed or removed.
Need to get 0 B/91.2 kB of archives.
After this operation, 555 kB of additional disk space will be used.
I don't need gnuradio on here - I am happy removing it, but I get the dependency errors when I apt-get remove. I worked through the first part of How do I resolve unmet dependencies after adding a PPA? (up to the PPA part) but no dice.
Other ideas? Even nuclear? Perfectly willing to just nuke all the gnuradio stuff and get a working machine back.
Try removing gr-osmosdr too. sudo apt-get remove libgnuradio-iqbalance gr-osmosdr
roadmr
  • 34,802
