I have upgraded my ubuntu 12.04, with fhe following command.
sudo apt-get upgrade In between some parts were not updated because of some internet issued. So, I had to again run the same command to again start the same upgradation process.
But after that i am unable to start my windows 7. Have no idea why
Instead of window's 7 Its showing Memtet86+, serial console 115200. Searched all over the internet applied most solutions from SOLVED answers but still no use.
Boot info Summary
One more strange thing, when I do grep menuentry /boot/grub/grub.cfg There is no info on windows 7, It provides me following info:
menuentry 'Ubuntu, with Linux 3.8.0-44-generic' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu, with Linux 3.8.0-44-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu, with Linux 3.8.0-42-generic' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu, with Linux 3.8.0-42-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu, with Linux 3.8.0-41-generic' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu, with Linux 3.8.0-41-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu, with Linux 3.8.0-39-generic' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu, with Linux 3.8.0-39-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu, with Linux 3.8.0-38-generic' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu, with Linux 3.8.0-38-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu, with Linux 3.8.0-29-generic' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry 'Ubuntu, with Linux 3.8.0-29-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
menuentry "Memory test (memtest86+)" {
menuentry "Memory test (memtest86+, serial console 115200)" {
Can anybody provide me the solution for this, as m unable to understand whats going on. Also dont want to corrupt MBR, GRUB etc with various hit n trial. And dont even know that I have already corrupted it. Have a very little knowledge of this linux n file systems so dont know whats going on.
EDIT
Output of sudo fdisk -l
Disk /dev/sda: 250.1 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders, total 488397168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x5fa00889
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *        2048      206847      102400    7  HPFS/NTFS/exFAT
/dev/sda2          206848   209717247   104755200    7  HPFS/NTFS/exFAT
/dev/sda3       209717248   347870802    69076777+   7  HPFS/NTFS/exFAT
/dev/sda4       347871230   488396799    70262785    5  Extended
/dev/sda5       347871232   484356095    68242432   83  Linux
/dev/sda6       484358144   488396799     2019328   82  Linux swap / Solaris
