I'm sorry to say you've accidentally overwritten your Windows installation. If you had no important data on the disk or if you have adequate backups from which you can restore your personal data, your best bet is to re-install Windows. If you had important personal data on the disk with no backups:
- STOP USING THE UBUNTU INSTALLATION IMMEDIATELY!! Every moment the computer is booted into Ubuntu, there's a risk that it will overwrite the sectors that still contain your personal data.
- Using an emergency system, make a low-level backup of your disk using
dd.
- Use PhotoRec or equivalent Windows-specific software to recover your personal files on a file-by-file basis. I've heard claims that some Windows tools do a better job than PhotoRec at recovering filenames, but I don't have specific recommendations on this score. You may want to ask about it on a Windows forum. Note that this process is going to be extremely tedious and is likely to recover only some of your personal files; it's very likely that some are irretrievably lost.
- Once you've recovered your personal files, re-install Windows and copy the files back to the new installation (or to your Ubuntu installation, if you prefer).
Note that this procedure requires you to have at least one disk of equal or greater size to the original to hold the backup and recovered files. If you don't have such a disk already, buy one. You can use it for more conventional backups in the future.
Good luck with your recovery efforts!
