Having intermittent issues when starting and stopping searches. I get a
Error: No space left on device
intermittently.
Have done some searches and most fixes are related to inodes, which you can see is not my issue.
It looks like the disk is not offset correctly but I do not think that is the issue.
jake@server:~$ sudo service crashplan start
jake@server:~$ sudo service couchdb start
jake@server:~$ df -h
Filesystem            Size  Used Avail Use% Mounted on
/dev/mapper/server-root   92G   18G   70G  20% /
udev                  2.0G     0  2.0G   0% /dev
tmpfs                 396M  6.5M  389M   2% /run
tmpfs                 2.0G  4.0K  2.0G   1% /dev/shm
tmpfs                 5.0M     0  5.0M   0% /run/lock
tmpfs                 2.0G     0  2.0G   0% /sys/fs/cgroup
/dev/sda1             228M   40M  176M  19% /boot
/dev/sdb2             3.6T  1.9T  1.6T  56% /media/data
tmpfs                 396M     0  396M   0% /run/user/1000
jake@server:~$ df -i
Filesystem              Inodes  IUsed     IFree IUse% Mounted on
/dev/mapper/server-root   6127616 348568   5779048    6% /
udev                    502768    506    502262    1% /dev
tmpfs                   506080    753    505327    1% /run
tmpfs                   506080      2    506078    1% /dev/shm
tmpfs                   506080      8    506072    1% /run/lock
tmpfs                   506080     12    506068    1% /sys/fs/cgroup
/dev/sda1               124496    299    124197    1% /boot
/dev/sdb2            244178944 378101 243800843    1% /media/data
tmpfs                   506080      4    506076    1% /run/user/1000
jake@server:~$ sudo fdisk -l
Disk /dev/sda: 97.7 GiB, 104857600000 bytes, 204800000 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00021678
Device     Boot  Start       End   Sectors  Size Id Type
/dev/sda1  *      2048    499711    497664  243M 83 Linux
/dev/sda2       501758 204797951 204296194 97.4G  5 Extended
/dev/sda5       501760 204797951 204296192 97.4G 83 Linux
Disk /dev/mapper/VS1-root: 93.4 GiB, 100298391552 bytes, 195895296 sectors
Disk /dev/mapper/VS1-swap_1: 4 GiB, 4299161600 bytes, 8396800 sectors
Disk /dev/sdb: 3.7 TiB, 4000754696192 bytes, 7813974016 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: BE311C90-F065-11E4-BEC1-C48508D2F365
Device      Start        End    Sectors  Size Type
/dev/sdb1      34     262177     262144  128M Microsoft reserved
/dev/sdb2  264192 7813973982 7813709791  3.7T Microsoft basic data
Partition 2 does not start on physical sector boundary.
Crashplan ended up having a wiki for this exact issue http://support.code42.com/CrashPlan/Latest/Troubleshooting/Real-Time_Backup_For_Network-Attached_Drives
The fix was adding
fs.inotify.max_user_watches=1048576
to /etc/sysctl.conf and restarting
