This is on Ubuntu 14.04 (SERVER, so no GUI)
Ok so earlier today I was asked to upgrade GCC to GCC 4.9 (current available is GCC 4.8 for Trusty).
So following these directions I installed the PPA ubuntu-toolchain-r/test. Well, turned out we did not need GCC 4.9 and I wanted to revert back to 4.8. So I followed these instructions and I:
Used ppa-purge tool:
sudo ppa-purge ppa:ubuntu-toolchain-r/test
I removed the repository with --remove
sudo apt-add-repository --remove ppa:ubuntu-toolchain-r/test
And manually removed the PPA file from /etc/apt/sources.list.d as well as the keyring.
But now, whenever I run
sudo apt-get upgrade
It's still asking me to upgrade GCC to 4.9 (and several other toolchain related packages.)
tucstwo
  • 73
All of what you did is just right. But you miss to do one important thing.
Now before doing
you should make
sudo apt-get update
then make
Your problem is you are still working on the software list that containing that repository, so you have to do apt-get update to update this list without the ubuntu-toolchain-r/test repository.
Maythux
  • 87,123
-1
The first command will only disable the PPA, not actually remove and install the original packages from Ubuntu repository:
So you'll need to enable the Repository one more time, go to Software Center > Edit menu > Sources, and run ppa-purge first.
xangua
  • 7,277
