I am dual booting linux and windows 8 on a lenovo yoga 2 pro. My speaker volume isn't working but headphone volume works fine. Alsa controls my audio and the speaker volume is on. I found that my card 0 is HDMI and not my actual audio card. I think this may be the source of the problem but I am scared to just rename things because I am new and I will probably just break everything. Any suggestions as to how I can fix this? Thanks in advance.
  • First try this: real shutdown from Windows
  • Then install "Pulseaudio volume control" (aka pavucontrol, which has more controls than standard "sound settings"):
    In the output device tab, you can select which device is the default for pulseaudio , clicking corresponding green button .
  • To change order at Alsa level: run this command :
    sudo gedit /etc/modprobe.d/alsa-base.conf
    so you can modify alsa-base.conf:
    add this line at the end:
    options snd-hda-intel index=1,0
    then save file and reboot.
    (from here)
laugeo
  • 2,880
  • 14
