Maybe you should have a look at my Question & Solution for a detailed analysis ...
In short the GNOME Virtual File System or gvfs is not working at all.
However Do Not unmount & remove the /run/user/[USER ID]/gvfs folder as suggested by other posters here (default User ID is 1000).
Find your gvfs folder and [USER ID]
$ mount | grep gvfs
gvfsd-fuse on /run/user/[USER ID]/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=jean)
List mount points used by gvfs. [NOTE: Since gvfs is not working it should be empty]
$ ls -als /run/user/[USER ID]/gvfs
total 0
0 dr-x------ 2 jean jean 0 Dec 22 17:42 .
0 drwx------ 10 jean jean 260 Dec 22 17:42 ..
Check whether the gvfsd daemon process is active
$ ps axu | grep gvfsd
jean 5993 0.0 0.0 680372 6356 ? Sl 17:42 0:00 /usr/lib/gvfs/gvfsd
Kill it with the following cmd.
$ sudo killall -9 gvfsd
Then relaunch the daemon (process)
$ sudo /usr/lib/gvfs/gvfsd-fuse /run/user/[USER ID]/gvfs
Well, that's it. It didn't show up straight as I needed to completely shutdown and restart the system (restarting the system without a complete shutdown will not work for me). But right after the system restart, gvfs worked fine and I had access to all partitions / drives within Nemo / Nautilus.
Previously, restarting the system would not solve anything.
