I'm on 11.10, and no wireless networks I create are staying connected. I had created one called "cookie" many moons ago, then deleted it some time after upgrading to 11.10.
Strangely, that network showed up today, after applying some updates, yet the system still will not remain connected to any ad-hoc networks I create. I reported a bug (as one should do) but it has been ignored for a long time now, and it is allegedly fixed, but I still have the problem.
See this output: http://pastebin.com/LAEB9H1u
What can I do to get normal functionality back? Is there some way to clean network manager's configuration so I can start with a clean slate without reinstalling the entire system?
RolandiXor
  • 51,797
Have you tried reinstalling NetworkManager? If you can connect via ethernet — because, naturally, removing NetworkManager would disconnect you — try:
sudo apt-get -y purge network-manager
sudo apt-get -y install network-manager
I have had problems with NetworkManager in the past, and therefore use wicd most of the time. However, it does not have certain features, like managing multiple interfaces at a time, and creating ad-hoc networks, etc., so I use NetworkManager when I have to, but otherwise, I use wicd.
Edit: If this does not work, please try the CLI method as described here: https://help.ubuntu.com/community/WifiDocs/Adhoc
Matt
  • 10,201
After a not so merry go round of purging network manager and reinstalling restarting, logging in and out about twice, deleting all networks, and trying again...
The maintainer told me it was ipv6. I set it to ignore and the network sticks :D!
RolandiXor
  • 51,797
