I tried to make a 14.04 live USB with Universal USB Installer. I get to the screen where it says Try Ubuntu, Install Ubuntu, etc. but no matter what I select, it eventually ends in this error;
end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
Does anyone know how to fix this? The computer that this is on is a Dell Inspiron 1545. I've seen a few cases around where you had to format the flash drive as FAT32, but I tried that and it still displayed the same message.
Sorry if this is a duplicate. Any help is appreciated!
Aqua001
  • 31
The most common reason for such cases is that the bootable USB disk is not readable - either because the hardware is failing, or because it was not written properly, or the image was corrupted during download.
I had the same problem and eventually found the answer here:
Kernel panic on boot up with 13.10 live-USB
In my case, the format of the bootable flash drive was not a format that windows could understand. I needed to format the flash drive as FAT32 and then use unetbootin to make it bootable again.
Zanna
  • 72,312
Isaac Betesh
  • 121
