12
I'm trying to remove a network interface permanently. For some reason, ifconfig lists eth0 and eth1, although the latter RX/TX metrics remain at zero.
I suspect that extra eth1 entry might be causing delays during boot.
Surprinsgly, a search did not yield any answer on how to proceed. Most posts either are for older versions of Ubuntu or Debian, or for other distros (RedHat), or have no permanent effect, or pertain to adding an interface, or try to turn it off but after it's been started, or are simply unanswered. But the answer might be somewhere after Google's thrid result page.
Removing the second entry from the desktop (up and down arrows, on the top bar) has no effect either on ifconfig.
EDIT: I actutally do have two network cards on the MB. That's a bit of a surprise I admit. I don't have wifi. Question still stands, a least out of curiosity.
krakoukass@durum:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr 00:1f:d0:a3:40:d9
          inet addr:192.168.1.66  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::21f:d0ff:fea3:40d9/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:84 errors:0 dropped:0 overruns:0 frame:0
          TX packets:93 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:12255 (12.2 KB)  TX bytes:12241 (12.2 KB)
eth1      Link encap:Ethernet  HWaddr 00:1f:d0:a3:40:db
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:634 errors:0 dropped:0 overruns:0 frame:0
          TX packets:634 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:64758 (64.7 KB)  TX bytes:64758 (64.7 KB)
krakoukass@durum:~$ lspci | grep -i eth
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 02)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 02)
krakoukass@durum:~$ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
krakoukas@durum:~$ systemctl -l status ifup@eth1.service
● ifup@eth1.service - ifup for eth1
   Loaded: loaded (/lib/systemd/system/ifup@.service; static; vendor preset: enabled)
   Active: active (exited) since Fri 2015-05-15 12:36:34 CEST; 14min ago
  Process: 457 ExecStart=/bin/sh -ec ifup --allow=hotplug %I; ifup --allow=auto %I;      if ifquery %I >/dev/null; then ifquery --state %I >/dev/null; fi (code=exited, status=0/SUCCESS)
 Main PID: 457 (code=exited, status=0/SUCCESS)
May 15 12:36:34 durum systemd[1]: Started ifup for eth1.
May 15 12:36:34 durum systemd[1]: Starting ifup for eth1...
May 15 12:36:34 durum sh[457]: Unknown interface eth1
krakoukas@durum:~$ systemctl -l status ifup@eth0.service
● ifup@eth0.service - ifup for eth0
   Active: active (exited) since Fri 2015-05-15 12:36:34 CEST; 15min ago
  Process: 458 ExecStart=/bin/sh -ec ifup --allow=hotplug %I; ifup --allow=auto %I;      if ifquery %I >/dev/null; then ifquery --state %I >/dev/null; fi (code=exited, status=0/SUCCESS)
 Main PID: 458 (code=exited, status=0/SUCCESS)
May 15 12:36:34 durum systemd[1]: Started ifup for eth0.
May 15 12:36:34 durum systemd[1]: Starting ifup for eth0...
May 15 12:36:34 durum sh[458]: Unknown interface eth0
Thanks in advance for you help.
youri
  • 870
To remove permanently I think you should use this
sudo nmcli connection show
The result looks like:
NAME                UUID                                  TYPE       DEVICE
front               2cf067c7-e0ad-4072-b60f-60a7733b5c27  wifi       wlp1s0
wg0                 ab0b9039-c4b1-48af-b30c-adcbea993643  wireguard  wg0
WebSolutions        07749022-afa7-467e-a625-a87de9875ab7  vpn        --
BlackHome           061a7dbf-5d7d-4992-a78d-015b3d93f5af  wifi       --
then remove by UUID
sudo nmcli connection delete ab0b9039-c4b1-48af-b30c-adcbea993643
10
Open the file /etc/network/interfaces in your terminal
sudo nano /etc/network/interfaces
Add this line:
iface eth1 inet manual
Save the file and run
sudo service network-manager restart
or
sudo systemctl restart network-manager.service
(NOTE: on a newer Ubuntu the network-manager service is renamed to NetworkManager service)
Source
mPrinC
  • 103
A.B.
  • 92,125
