11
I am looking for a script that creates a rotation animation using character /,-, | and \.
If you continuously switch between these characters it should look like its rotating. How to make this?
Use that script:
#!/bin/bash
chars="/-\|"
while :; do
  for (( i=0; i<${#chars}; i++ )); do
    sleep 0.5
    echo -en "${chars:$i:1}" "\r"
  done
done
The while loop runs infinite. The for loop runs trough each character of the string given in $chars. echo prints the character, with a carriage return \r, but without linebreak -n. -e forces echo to interpret escape sequences such as \r. There's a delay of 0.5 seconds between each change.
chaos
  • 28,186
22
Here's an example using \b, which tells the terminal emulator to move the cursor one column to the left, in order to keep overwriting the same character over and over.
#!/usr/bin/env bash
spinner() {
    local i sp n
    sp='/-\|'
    n=${#sp}
    printf ' '
    while sleep 0.1; do
        printf "%s\b" "${sp:i++%n:1}"
    done
printf 'Doing important work '
spinner &
sleep 10  # sleeping for 10 seconds is important work
kill "$!" # kill the spinner
printf '\n'
See BashFAQ 34 for more.
geirha
  • 47,279
very minimal way of writing using printf
sh-5.1$ while true ; do for i in \\ "|" / "-"; do printf "$i" ; sleep 0.1 ; printf "\b" ; done ; done
Since you don't explicitly ask for bash, a little plug for the fish shell, where this can be solved beautifully IMO:
set -l symbols ◷ ◶ ◵ ◴
while sleep 0.5
    echo -e -n "\b$symbols[1]"
    set -l symbols $symbols[2..-1] $symbols[1]
end
In this case, symbols is an array variable, and the contents if it are rotated/shifted, because $symbols[2..-1] are all entries but the first.
Pompei2
  • 111
