I'm currently writing a Bash script. I want to download a file while printing text. For example, consider this script:
echo -e "---------------------------"
echo -e "Your file downloading..."
wget example.com/1gbfile
In the second echo each . should be printed successively every second till the download finishes. If the number of . becomes three, like this: ..., it should be reset to only one . and continue the loop.
Erikli
  • 429
Main script:
Create the following script as the source for your progress/bouncing bar (I called it bash-progress):
#!/bin/bash
Initial configuration variables
Set time interval for progress delay (in fraction of seconds)
time_delay=".2"
Set left and right brackets (1 character)
lb="["
lb="("
lb=" "
rb="]"
rb=")"
rb=" "
Function to show bouncing bar while running command in the background
show_bouncer() {
If no argument is given, then this is run on the last command - else provide PID
if [[ -z $1 ]] then PID=$! else PID=$1 fi ii=0
Define bouncer array (3 characters)
bo=('. ' '.. ' '...' ' ..' ' .' ' ..' '...' '.. ')
bo=('⠄ ' '⠂⠄ ' '⠁⠂⠄' '⠂⠂⠂' '⠄⠂⠁' ' ⠄⠂' ' ⠄' ' ')
bo=('⡇ ' '⣿ ' '⣿⡇ ' '⢸⣿ ' ' ⣿⡇' ' ⢸⡇' ' ⡇' ' ')
True while the original command is running
while [[ -d "/proc/$PID" ]] do ch="${bo[(ii++)%${#bo[@]}]}" printf "%b" " ${lb}${ch}${rb}" sleep "$time_delay" # Adjust backspaces to bouncer length + 3 printf "\b\b\b\b\b\b" done }
The script can work in 2 ways: Either by using the PID of the last command run, or with a given PID. The most common use is with the last command.
Using it:
So you simply create your other script like this:
#!/bin/bash
Include Bash progress bars - or include the entire source in your script.
source "./bash-progress"
your_command_here & show_bouncer
It's important to run the command in the background, since it then moves on immediately to show the bouncer.
You can easily test it with a sleep command:
#!/bin/bash
sleep 5 & show_bouncer
Bonus info:
To use with a PID other than the last one, you can use pgrep (-n for newest and -x for exact match) to find the latest instance of the process like this:
#!/bin/bash
your_command & do_something_else do_anything_meanwhile show_bouncer $(pgrep -nx "your_command")
Artur Meinild
  • 31,035
