19
After a new install on my newly-built HTPC, I can't boot! I end up in initramfs every time, and get lots of ata2: COMRESET failed (errno=16)
Full error here:
ata2.00 exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
ata2.00: cmd a0/01:00:00:60:00/00:00:00:00:00/a0 tag 0 dma 96 in
         res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
ata2.00: status: { DRDY }
ata2.00: COMRESET failed (errno=16)
The machine:
  • Board: ASUS AT3IONT-I Duluxe
  • 2Gigs of OCZ Ram
  • 80GB Western Digital Laptop Harddrive
  • Ubuntu 11.04 Minimal
More details:
  • I've done multiple re-installs
  • I've done a disk check
  • I've done a CPU check
  • I've done a memory check
  • I've filled the first and last million bytes with zeros using Ultimate Boot CD
  • Checked SATA ports are enabled
  • Tried RAID, SATA, and AHCI modes
  • Tried all new sata cables.
  • Tried booting Arch from a USB - similar error: [sda] No caching mode page present and Error: boot device didn't show up after 30 seconds, then chucked into initramfs.
Help?
I had this problem just now. Apparently it looks like a problem with a hard disk partition. I solved it like this:
  • When you get initram, type exit.
  • It gives you an menu with options. Select fsck.
  • Let it scan the hard drive. When its done hit the return key and it will immediately take you to login screen.
I noticed that the /home was not mounted when I checked in the initramfs. This should be because of your hard drive. Everything was fine when I did a normal shutdown of my system a month ago. This just happend when I started it today.
Anyways my system is up now. :-)
MadMike
  • 4,275
  • 29
  • 50
preetam
  • 211
