When I add a new command to kcron it seems to work fine. I hit Run Now and it works perfectly. BUT when the task is scheduled it never runs. How do I get kcron to run commands exactly as Konsole can run them?
For example if I run xdotool key Ctrl+Alt+l
it works fine from the Konsole and from the Run Now button. BUT it never runs otherwise.
Same for soffice
which will open the LibreOffice splash screen.
Gnome-Schedule will run most commands. BUT I want to use KDE native stuff and would love to get kcron running.
I am running kubuntu 14.04.2 fully updated. Have tried on 32 bit and 64 bit machines.
KCron & Cron
KDE UserBase KCron: https://userbase.kde.org/KCron
KCron is a tool for running applications in the background at regular intervals. It's a graphical interface to the Cron command.
Ubuntu Community Cron HowTo: https://help.ubuntu.com/community/CronHowto
GUI Applications
It is possible to run gui applications via cronjobs. This can be done by telling cron which display to use.
00 06 * * * env DISPLAY=:0 gui_appname
The env DISPLAY=:0 portion will tell cron to use the current display (desktop) for the program "gui_appname".
man xdotool
KEYBOARD COMMANDS
       key [options] keystroke [keystroke ...]
           Options:
           --window window
               Send keystrokes to a specific window id. You can use "WINDOW STACK" references like "%1" and "%@"
               here. If there is a window stack, then "%1" is the default, otherwise the current window is used.
It needs a window.
More of the KCron and Cron:
user26687
  • 15,174
I have given up on this. Tried everything imaginable. Kalarm which is also native to KDE runs great. It is easy to use and schedule and will run anything I can do in the Konsole.
