The service management system has changed.
Every system management toolset has own utilities.  The utilities that you are used to using are the ones that come with upstart, which are trivial shims for initctl start and initctl stop.  But this is Ubuntu version 15.  You aren't using upstart any more.
You're using systemd, and the service control commands are subcommands of systemctl rather than of initctl.  So services are started with systemctl start, stopped with systemctl stop, enabled with systemctl enable, disabled with systemctl disable, and queried with systemctl status.
Services and service configuration have changed.
You've presumably followed instructions like the Serial Console How-To to turn the supplied /etc/init/tty1.conf into an /etc/init/ttyS0.conf.  This is an upstart configuration file and it will simply be ignored by systemd.  None of what you have learned from there applies to systemd, not even the concept of run levels, which is "obsolete" in the systemd world.
The systemd configuration file for a getty on a real terminal device is /lib/systemd/system/serial-getty@.service.  This is a template unit, parameterized on the name of the serial device file.  So the actual service name to use will be serial-getty@ttyS0.service.  You just enable/disable/start/stop it like any other service.
If you want an actual serial console, rather than just an ordinary serial terminal, then you don't even do that.  systemd has a mechanism that automatically instantiates serial-getty@.service whenever the kernel is told to not have its console on a virtual terminal.
Further reading
