I installed Ubuntu 15.04, but I need to use PHP 5.5 and in 15.04 the standard is PHP 5.6
I added the PPA:
sudo add-apt-repository ppa:ondrej/php5
But when I tried to install, I got:
    php5-mcrypt : Depends: phpapi-20121212 Depends: php5-common (= 5.5.24+dfsg-1+deb.sury.org~vivid+1)
but 5.6.4+dfsg-4ubuntu6 is to be installed
How should I proceed?
Fabby
  • 35,017
If you really need PHP 5.5, than install this version with this command (for version 5.5.24+dfsg-1+deb.sury.org~vivid+1) and check the correct version here:
sudo apt-get install php5=5.5.24+dfsg-1+deb.sury.org~vivid+1
and set the package on hold:
sudo apt-mark hold php5
Otherwise you'll get in the next update again version 5.6
A.B.
  • 92,125
The PPA maintainer has a separate PPA for use with PHP 5.6. I recommend that you use this PPA instead of downgrading to PHP 5.5
saiarcot895
  • 10,917
