I am working on a codeigniter project where the system requires php version < 5.6 that is 5.5, but few days ago I have installed ubuntu 15.04 with having LAMP stack installed using tasksel;the tasksel is gives me the latest update to php5.6 which is incompatible to my project;even I have uninstall tasksel LAMP server and installed lamp individually but the problem is not persisted
I have a limited knowledge in linux environment if anybody knows please help me with some resources;I will be highly obliged.
Thank You.
You should run sudo apt-get remove php5, then for 5.5 specifically, which was not used in 15.04, you will need to add a source from utopic by opening /etc/apt/sources.list in your favorite text editor and adding the following lines deb http://us.archive.ubuntu.com/ubuntu utopic main and deb-src http://us.archive.ubuntu.com/ubuntu utopic main. Next, to ensure you get the proper version, open /etc/apt/preferences in a text editor and add the following lines
Package: *
Pin: release n=trusty
Pin-Priority: 501
Package: php5
Pin: release n=utopic
Pin-Priority: 502
This will ensure that all packages are installed from trusty except for php5, which will be installed from utopic.
As with installing any outdated version of a piece of software, this can introduce security risks that you should consider. Also, this may affect the stability of php5 so keep that in mind.
