41
I'm new to Ubuntu and want to disable the turbo boost. I tried with cpufreq but i cant get it to work. is there any other way to do it.
In windows it was as easy as changing the CPU speed from 100 to 99.
Maythux
  • 87,123
Ivaylo
  • 459
If your system is using the intel_pstate frequency scaling driver:
$ cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_driver
intel_pstate
intel_pstate
intel_pstate
intel_pstate
intel_pstate
intel_pstate
intel_pstate
intel_pstate
Then you can inquire as to the turbo enabled or disabled status:
$ cat /sys/devices/system/cpu/intel_pstate/no_turbo
Where 0 means turbo is enabled and 1 means it is disabled. And you can change it by writting (as sudo) to the same location.
$ echo "1" | sudo tee /sys/devices/system/cpu/intel_pstate/no_turbo
I never remember the location or how to do the `tee' thing properly, so I prefer scripts to be run as sudo:
$ cat set_cpu_turbo_off
#! /bin/bash
echo "1" > /sys/devices/system/cpu/intel_pstate/no_turbo
$ cat set_cpu_turbo_on
#! /bin/bash
echo "0" > /sys/devices/system/cpu/intel_pstate/no_turbo
Doug Smythies
  • 16,146
31
To read the current state of the Turbo Boost, we need to install the msr-tools
sudo apt-get install msr-tools
To know if the Turbo Boost feature is disabled, run:
rdmsr -pi 0x1a0 -f 38:38
1=disabled
0=enabled
Replace i with your cores number
NOte: If you get the following error:
rdmsr:open: No such file or directory
then load the “msr” module by the following command:
sudo modprobe msr
To disable the Turbo Boost feature, one can set the entire 0x1a0 MSR register to 0x4000850089, as in here:
wrmsr -pC 0x1a0 0x4000850089
Where C refers to a particular core number
ou can get those number by running
cat /proc/cpuinfo | grep processor
then once you know your numbers you have to run the command above for each core. in your case numbers would be 0 & 1 so you have to do
wrmsr -p0 0x1a0 0x4000850089
wrmsr -p1 0x1a0 0x4000850089
Solution stands for this blog
From http://notepad2.blogspot.com/2014/11/a-script-to-turn-off-intel-cpu-turbo.html
A script to disable/enable turbo boost
The following script can be used to turn off/on turbo boost:
#!/bin/bash
if [[ -z $(which rdmsr) ]]; then
    echo "msr-tools is not installed. Run 'sudo apt-get install msr-tools' to install it." >&2
    exit 1
fi
if [[ ! -z $1 && $1 != "enable" && $1 != "disable" ]]; then
    echo "Invalid argument: $1" >&2
    echo ""
    echo "Usage: $(basename $0) [disable|enable]"
    exit 1
fi
cores=$(cat /proc/cpuinfo | grep processor | awk '{print $3}')
for core in $cores; do
    if [[ $1 == "disable" ]]; then
        sudo wrmsr -p${core} 0x1a0 0x4000850089
    fi
    if [[ $1 == "enable" ]]; then
        sudo wrmsr -p${core} 0x1a0 0x850089
    fi
    state=$(sudo rdmsr -p${core} 0x1a0 -f 38:38)
    if [[ $state -eq 1 ]]; then
        echo "core ${core}: disabled"
    else
        echo "core ${core}: enabled"
    fi
done
save this to a file called turbo-boost.sh
Usage: You can copy the above script and save it into a file named turbo-boost then set it to be executable:
sudo chmod +x turbo-boost.sh
you can then use it to disable/enable turbo boost:
./turbo-boost.sh disable
./turbo-boost.sh enable
Maythux
  • 87,123
You can try setting /sys/devices/system/cpu/cpufreq/boost value to 0.
echo "0" | sudo tee /sys/devices/system/cpu/cpufreq/boost
Charles Green
  • 21,859
Ron
  • 20,938
-1
In my case this works:
echo "0" | sudo tee /sys/devices/system/cpu/intel_pstate/no_turbo
