I'm trying to get OTRS 4.0 working on Ubuntu 14.04. I've followed all instructions to install from source.
When I open the site (localhost/otrs/index.pl), an empty .pl-file is served for download. Apparently Apache finds the index.pl, but does not know what to do with it.
  • OTRS is installed with all relevant perl modules (checked by install script)
  • Vhost is copied from scripts folder in OTRS
  • hosts is updated for the local test domain
  • Apache is restarted
Modules
cgi.load -> ../mods-available/cgi.load
perl.load -> ../mods-available/perl.load
Question
How can I get Perl working with Apache?
SPRBRN
  • 2,535
Make sure you have set the following path in your /etc/apache2/apache2.conf:
ScriptAlias /cgi-bin/ "/path/to/cgi-bin/" and that your scripts are in that folder.
If your scripts ends on .pl make sure to change the line
AddHandler cgi-script .cgi to AddHandler cgi-script .cgi .pl
in /etc/apache2/apache2.conf and check that it is not commented out.
Options FollowSymLinks +ExecCGI needs to set in your virtual host.
Pabi
  • 7,429
Waking the dead but with the answer. Do this:
ln -s /etc/apache2/mods-available/cgid.load /etc/apache2/mods-enabled/
ln -s /etc/apache2/mods-available/cgid.conf /etc/apache2/mods-enabled/
sudo service apache2 restart
and it works.
