Hey people of the internet!
I have a problem saving/restoring the brightness on my laptop... I am running Ubuntu 15.04 server, with Xfce4, but booting default to command line.
My problem now is, unless I start up Xfce and change the brightness via xBacklight -set 5, nothing changes the brightness of my display. Having the command promt on full brightness looks nice, but eats battery like hell, and i don't need it.
I've read about using systemd-backlight - something, but I can't find anything on how to use it or make it so it restores my brightness on bootup...also, does this work without starting up X? Is there even a way to change the screen brightness without starting X?
(if it matters: running an Asus N550JK which has an intel and nvidia dual graphics thing, called optimus...I'm not using that, only using the intel one. xBacklight changes the value in /sys/class/backlight/intel_backlight/brightness, my desired value would be 244)
Thanks for everything!
Ron
  • 20,938
Many of these things are quite poorly documented in systemd. The documentation pretty much boils down to "systemd-wibble.service is a service that runs systemd-wibble, and systemd-wibble is a program run by systemd-wibble.service; and it wibbles.". There's no real explanation of how, when, or where; or clue as to how this fits into an overall system. The systemd-backlight manual page is a case in point.
What happens is this:
You don't run the service, or the program, directly. Instead:
  1. A udev rule is triggered by the presence of "backlight" or "leds" devices on your system. (It's in the the 99-systemd.rules list.)
  2. udev takes the name of the device that triggered the rule and incorporates it into a service name.
  3. This service is an instantiation of the systemd-backlight@.service service template unit file.
  4. udev tells systemd to activate the service.
  5. The service unit file causes the template parameter to be passed as a command-line argument to the systemd-backlight command, which then does its thing.
In your case, this would end up activating a systemd-backlight@backlight:intel_backlight.service service, which would end up running systemd-backlight start backlight:intel_backlight
So your basic problem could be one of three things: your service unit is masked, the udev rule isn't triggering, or it's not triggering as the right kind of device.
systemctl status systemd-backlight@backlight:intel_backlight.service should give you some idea.
Halil
  • 119
JdeBP
  • 3,979
Try the suggestion here and see if it works for you. So open the file:
sudo nano /etc/rc.local
and add the following line:
echo 244 > /sys/class/backlight/intel_backlight/brightness
Reboot and see if this helped you.
Ron
  • 20,938
I have a Dell laptop with Nvidia and Intel graphics and was facing a similar problem.
With help from the answer above by JdeBP and this post from the ArchLinux forums here is what I did to resolve the problem(for now):
As root:
echo 1 > /sys/class/backlight/dell_backlight/brightness
/lib/systemd/systemd-backlight save backlight:dell_backlight
This created a file in /var/lib/systemd/backlight named platform-dell-laptop:backlight:dell_backlight with the value 1. A similar attempt with intel backlight did not seem to work.
It appears for now that the systemd-backlight service is reading this value on boot and setting the display brightness accordingly.
user74112
  • 73
