I'm having trouble connecting to my company's VPN on Ubuntu 15.04. It uses L2TP over IPsec, and I have a username, password and shared secret. How do I connect?
Update:
A PPA exists now for network-manager-l2tp:
You can use
sudo add-apt-repository ppa:nm-l2tp/network-manager-l2tp
sudo apt-get update
sudo apt-get install network-manager-l2tp
To install the network manager l2tp that supports L2TP for Ubuntu 16.04
Walkthrough for building from source: http://blog.z-proj.com/enabling-l2tp-over-ipsec-on-ubuntu-16-04/
Old Answer
Another solution is to use network-manager-l2tp. You can get it from https://github.com/nm-l2tp/network-manager-l2tp.
For installation walk-through: http://blog.z-proj.com/enabling-l2tp-over-ipsec-on-ubuntu-16-04/
It works for Ubuntu 16.04
- 551
Patch NM-L2TP package with script
#!/bin/bash
CUR_PATH=$(dirname $(readlink -f $0))
TMP_PATH=/tmp/nm-l2tp
mkdir ${TMP_PATH}
cd ${TMP_PATH}
wget https://launchpad.net/~seriy-pr/+archive/ubuntu/network-manager-l2tp/+build/6512073/+files/network-manager-l2tp_0.9.8.5-0utopic1_amd64.deb
ar vx network-manager-l2tp_0.9.8.5-0utopic1_amd64.deb
mkdir new
tar -xpvf data.tar.xz -C ./new
mv ./new/usr/lib/pppd/2.4.5 ./new/usr/lib/pppd/2.4.6
sed -i 's/2.4.5/2.4.6/g' ./new/usr/lib/NetworkManager/nm-l2tp-service
sed -i 's/2.4.5/2.4.6/g' ./new/usr/lib/pppd/2.4.6/nm-l2tp-pppd-plugin.so
mkdir new/DEBIAN
tar -xpvf control.tar.gz -C ./new/DEBIAN
sed -i 's/, ppp (<< 2.4.6)//g' ./new/DEBIAN/control
sed -i 's/0utopic1/0vivid1/g' ./new/DEBIAN/control
rm ./new/DEBIAN/md5sums
dpkg-deb -b ./new/ ${CUR_PATH}/network-manager-l2tp_0.9.8.5-0vivid1_amd64.deb
rm -rf ${TMP_PATH}
Then download and install an appropriate Openswan package from the http://www.ubuntuupdates.org/pm/openswan and run the following commands
sudo apt-get update
sudo dpkg -i network-manager-l2tp_0.9.8.5-0vivid1_amd64.deb
sudo service xl2tpd stop
sudo update-rc.d xl2tpd disable
Then just go to the Network manager, choose VPN connections and create l2tp. You need only set up a username, password and the IPSec PSK in the IPSec additional settings.
Part taken from this answer
The first comment is probably the answer for most of us, except, maybe, some real experts:
"Seems there is no easy way anymore to establish a L2tp VPN connection since OpenSwan has been deprecated and removed in Ubuntu 14.10. Need it myself, found no working solution after months of sporadic research. – derFunk May 21 at 18:11"
No solution seems to be planned, see https://wiki.strongswan.org/issues/254. Another needed functionality removed from Ubuntu.
- 191
Note that for the accepted answer, the correct installation command for Ubuntu 18 is
sudo apt install network-manager-l2tp network-manager-l2tp-gnome
Since Ubuntu now ships with Gnome.
- 121
Another workaround, tested on 15.10, should work on 15.04 also. Requires manual editing of conffiles and manual establishing connection.
- leave original strongswan from ubuntu repo
- remove xl2tpd package (U can try with xl2tpd but on my computer xl2tpd crashed with segfault on every start)
- install openl2tpd from: ftp://ftp.openl2tp.org/releases/openl2tp-1.8/debian-squeeze/openl2tp_1.8-1_amd64.deb
- edit /etc/ipsec.conf:
config setup
strictcrlpolicy=yes
conn %default
ikelifetime=30m
keylife=15m
rekeymargin=3m
keyingtries=1
mobike=no
dpdaction=restart
dpddelay=30
dpdtimeout=120
conn MYSERVER
left=192.168.101.157
leftprotoport=17/1701
right=77.78.79.80 # public IP of VPN gw
rightprotoport=17/1701
authby=secret
type=transport
keyexchange=ikev1
auto=route
- edit /etc/ipsec.secrets:
: PSK "StrongPSKgivenByProvider"
- edit (or create) /etc/openl2tpd.conf:
ppp profile modify profile_name=default \
auth_eap=no auth_mschapv1=no auth_mschapv2=no
tunnel create tunnel_name=MYSERVER \
dest_ipaddr=77.78.79.80 \
hello_timeout=10 \
retry_timeout=10 \
max_retries=60 \
persist=yes
session create session_name=MeOnMYSERVER \
interface_name=ppp1 \
user_name=MyLogin \
user_password=MyPassword
restart and test ipsec:
ipsec restart ipsec statusoutput should be like this:
Routed Connections: MYSERVER{1}: ROUTED, TRANSPORT MYSERVER{1}: 192.168.101.157/32[udp/l2f] === 77.78.79.80/32[udp/l2f] Security Associations (0 up, 0 connecting): noneconnect
sudo service openl2tpd restart sudo route add -net {net_behing_VPN_gateway/mask} gw {local_IP_of_VPN_gw}
Hope this helps someone.
There is a workaround to get l2tp-ipsec on 15.04 but its not very elegant.
I uninstalled strongswan and installed an old openswan trusty .deb package.
http://packages.ubuntu.com/trusty/openswan
I then found .deb files of the old l2tp-ipsec-vpn and l2tp-ipsec-vpn-daemon from trusty by Werner Jaeger.
http://packages.ubuntu.com/trusty/l2tp-ipsec-vpn
http://packages.ubuntu.com/trusty/l2tp-ipsec-vpn-daemon
I installed those, and after I restarted, I was able to connect. However, this took quite a bit of time to get working properly and required installing deprecated packages.
I think that's all I did but if you try this and get another error there may be another package I installed I don't remember.
UPDATE: I had to do this again so I figured I would share the steps. Install the old client: https://launchpad.net/l2tp-ipsec-vpn
Again this is a workaround if you need it in pinch and currently works. That being said, this really needs to be apart of the OS.
sudo apt-get install gksu libgksu2-0 libctemplate2 libengine-pkcs11-openssl libp11-2 xl2tpd
Next download the old binaries and install with dpkg:
wget http://mirrors.kernel.org/ubuntu/pool/universe/o/openswan/openswan_2.6.38-1_amd64.deb
sudo dpkg -i openswan_2.6.38-1_amd64.deb
wget http://mirrors.kernel.org/ubuntu/pool/universe/l/l2tp-ipsec-vpn/l2tp-ipsec-vpn_1.0.9-1_amd64.deb
wget http://mirrors.kernel.org/ubuntu/pool/universe/l/l2tp-ipsec-vpn-daemon/l2tp-ipsec-vpn-daemon_0.9.9-1_amd64.deb
sudo dpkg -i l2tp-ipsec-vpn_1.0.9-1_amd64.deb
sudo dpkg -i l2tp-ipsec-vpn-daemon_0.9.9-1_amd64.deb
Open the client. Add a connection and configure as needed. Once you try to connect it may take awhile but be patient.
- 111
