I've installed StrongSwan and the network manager helper and I have the options in the applet for VPN, but it only supports certificate configuration, not PSK entry.
I've tried to add the PSK into the /etc/ipsec.secrets file but I don't know what syntax I should use to identify the connection. I simply get "The VPN connection 'VPN Connection 1' failed because of invalid VPN secrets".
Install the old client: https://launchpad.net/l2tp-ipsec-vpn
First install required packages:
sudo apt-get install gksu libgksu2-0 libctemplate2 libengine-pkcs11-openssl libp11-2 xl2tpd
Next download the old binaries and install with dpkg:
wget http://mirrors.kernel.org/ubuntu/pool/universe/o/openswan/openswan_2.6.38-1_amd64.deb
sudo dpkg -i openswan_2.6.38-1_amd64.deb
wget http://mirrors.kernel.org/ubuntu/pool/universe/l/l2tp-ipsec-vpn/l2tp-ipsec-vpn_1.0.9-1_amd64.deb
wget http://mirrors.kernel.org/ubuntu/pool/universe/l/l2tp-ipsec-vpn-daemon/l2tp-ipsec-vpn-daemon_0.9.9-1_amd64.deb
sudo dpkg -i l2tp-ipsec-vpn_1.0.9-1_amd64.deb
sudo dpkg -i l2tp-ipsec-vpn-daemon_0.9.9-1_amd64.deb
Open the client. Add a connection and configure as needed. Once you try to connect it may take awhile but be patient.
badmadrad
  • 111
You should try the NetworkManager L2TP plugin, but now that it is a few years later you may also want to upgrade to a newer release of Ubuntu (as 16.04 is the current LTS).
I followed this blog post to install the PPA and the Gnome NM applet and was able to use a PSK VPN with a username and password prompt (though it can be saved into the connection file as well).
Code to add the PPA and install the software.
sudo add-apt-repository ppa:nm-l2tp/network-manager-l2tp
sudo apt update
sudo apt install network-manager-l2tp-gnome
dragon788
  • 1,716
