I got a Bamboo Pad graphic tablet, which does not work. I'm running standard Ubuntu 15.04 on a Lenovo Yoga 2 pro.
I tried updating grub and other tips given here which seem to work in 14.10, but do not seem to work in 15.04 (someone else had the same problem).
Here is the result of lsusb:
Bus 001 Device 008: ID 056a:0318 Wacom Co., Ltd
benjou
Ok, I got halfway there. Thank you all for your responsiveness.
  1. using the usbhid.quirks trick did not change anything. This trick used to work in 14.10. It does not appear to work in 15.04
  2. updating kernel to 4 made my pad work. I used the following method to upgrade
Now only the stylus input work. The finger input does not, neither the bottom button. Adding the MatchIsTablet "on" did not solve this.
edit: when I run dmesg | grep -i wacom
here is what I get
 [    1.457401] usb 1-2: Manufacturer: Wacom Co.,Ltd.
    [    2.813078] input: Wacom HID Pen as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:056A:0318.0006/input/input13
    [    2.813174] wacom 0003:056A:0318.0006: hidraw1: USB HID v1.10 Device [Wacom Co.,Ltd. Bamboo Pad, USB] on usb-0000:00:14.0-2/input0
    [    2.813304] input: Wacom HID Pen as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:056A:0318.0007/input/input15
    [    2.813393] wacom 0003:056A:0318.0007: hidraw2: USB HID v1.10 Device [Wacom Co.,Ltd. Bamboo Pad, USB] on usb-0000:00:14.0-2/input1
    [    2.813545] input: Wacom HID Pen as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.2/0003:056A:0318.0008/input/input17
    [    2.813602] wacom 0003:056A:0318.0008: hidraw3: USB HID v1.10 Mouse [Wacom Co.,Ltd. Bamboo Pad, USB] on usb-0000:00:14.0-2/input2
So a mouse is detected, additionally to two pens. How do I configure it to work?
benjou
There is a bug (you can access it here) that seems to describe your issue. Although it's a little bit old, the solution should still work.
From the #38 reply:
Got it perfectly running, now someone can help to get it fixed for all by default. So the steps are:
  1. Add usbhid.quirks=0x056a:0x0319:0x40000000 to the grub boot cmdline(/etc/default/grub). Now the tablet is already working with wacom driver but automatically assigned wacom driver doesn't support touchpad and it's keyboard part
  2. I have added to 50-wacom.conf (/usr/share/X11/xorg.conf.d/) the line
     MatchIsTablet "on"
in the first section after
     MatchProduct "Wacom|WACOM|Hanwang|PTK-540WL|ISD-V4"
This way evdev works for keyboard and pad parts of the device and wacom only for tablet
Everything works, including three-finger swipes(which are sent by keyboard driver as Alt-Left, Alt-Right, Super etc) and pressure sensitivity of pen! There must be a better way to match Bamboo Pad without breaking the generic wacom file but I have no experience of doing that, still I will try later if no one else does it faster.
For the wired edition replace 0x0319 with 0x0318 in the grub cmdline
