I'm trying to get Bamboo Pad working on Ubuntu 14.04
  1. I am sure that device is not broken = I can see it via lsusb
  2. All "howtogetyourwacomtabletworking" guides are designed for older versions of Ubuntu (below 14.04 version). That means that there is always some step which is not working.
    ...to illustrate this irritating situation some guides recommend to install wacom-dkms package.
    sudo add-apt-repository ppa:doctormo/wacom-plus sudo apt-get update sudo apt-get install wacom-dkms
However, there is no "wacom-dkms" package in that PPA, and, in fact, no packages for 14.04 at all (as I know from @mikewhatever, although I have no slightest idea what PPA is). So I began to believe (after hours of googling how to solve this problem) that there is maybe no driver on 14.04.
  1. I tried this as my last chance (but error again):
What this means?
Here is full script I've run.
ladislav@Skynet:~/Plocha$ cd input-wacom-0.23.0
ladislav@Skynet:~/Plocha/input-wacom-0.23.0$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking for style of include used by make... GNU
checking dependency style of gcc... none
checking for kernel type... Linux
checking for linux-based kernel... yes
checking for kernel source/headers... /lib/modules/3.13.0-37-generic/build
checking kernel version... 3.13.0-37-generic
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating 2.6.30/Makefile
config.status: creating 2.6.36/Makefile
config.status: creating 2.6.38/Makefile
config.status: creating 3.7/Makefile
config.status: creating config.h
config.status: executing depfiles commands
make  all-recursive
make[1]: Entering directory `/home/ladislav/Plocha/input-wacom-0.23.0'
Making all in 3.7
make[2]: Entering directory `/home/ladislav/Plocha/input-wacom-0.23.0/3.7'
    Building input-wacom drivers for 2.6 kernel.
make -C /lib/modules/3.13.0-37-generic/build M=/home/ladislav/Plocha/input-wacom-0.23.0/3.7
make[3]: Entering directory `/usr/src/linux-headers-3.13.0-37-generic'
  LD      /home/ladislav/Plocha/input-wacom-0.23.0/3.7/built-in.o
  CC [M]  /home/ladislav/Plocha/input-wacom-0.23.0/3.7/wacom_wac.o
  CC [M]  /home/ladislav/Plocha/input-wacom-0.23.0/3.7/wacom_sys.o
  LD [M]  /home/ladislav/Plocha/input-wacom-0.23.0/3.7/wacom.o
  CC [M]  /home/ladislav/Plocha/input-wacom-0.23.0/3.7/wacom_w8001.o
  Building modules, stage 2.
  MODPOST 2 modules
  CC      /home/ladislav/Plocha/input-wacom-0.23.0/3.7/wacom.mod.o
  LD [M]  /home/ladislav/Plocha/input-wacom-0.23.0/3.7/wacom.ko
  CC      /home/ladislav/Plocha/input-wacom-0.23.0/3.7/wacom_w8001.mod.o
  LD [M]  /home/ladislav/Plocha/input-wacom-0.23.0/3.7/wacom_w8001.ko
make[3]: Leaving directory `/usr/src/linux-headers-3.13.0-37-generic'
make[2]: Leaving directory `/home/ladislav/Plocha/input-wacom-0.23.0/3.7'
make[2]: Entering directory `/home/ladislav/Plocha/input-wacom-0.23.0'
make[2]: Leaving directory `/home/ladislav/Plocha/input-wacom-0.23.0'
make[1]: Leaving directory `/home/ladislav/Plocha/input-wacom-0.23.0'
  BUILD ENVIRONMENT:
       linux kernel - yes 3.7
      kernel source - yes /lib/modules/3.13.0-37-generic/build
Your wacom.ko is available under
If you have an USB device, you can copy the driver by:
    cp 3.7/wacom.ko /lib/modules/3.13.0-37-generic/kernel/drivers/input/tablet
If you have a serial device, please copy the driver by:
    cp 3.7/wacom_w8001.ko /lib/modules/3.13.0-37-generic/kernel/drivers/input/touchscreen
NOTE: The kernel drivers included in this package are only
tested with the X Wacom driver built from xf86-input-wacom.
 If you are running an X server version older than 1.7,
please use the drivers provided by linuxwacom package.
ladislav@Skynet:~/Plocha/input-wacom-0.23.0$ cp 3.7/wacom.ko /lib/modules/3.13.0-37-generic/kernel/drivers/input/tablet
cp: nie je možné vytvoriť obyčajný súbor ( = Is not possible to create "ordinary" file)  `/lib/modules/3.13.0-37-generic/kernel/drivers/input/tablet/wacom.ko': Prístup odmietnutý ( = Access denied)
here is my lsusb output:
ladislav@Skynet:~$ lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 0930:0220 Toshiba Corp.
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
Bus 003 Device 003: ID 12d1:1c08 Huawei Technologies Co., Ltd.
Bus 003 Device 007: ID 056a:0319 Wacom Co., Ltd
Bus 003 Device 005: ID 04ca:7018 Lite-On Technology Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Does anybody know how to solve this? Any giude for 14.04 will be helpful.
Ladislav Naďo
  • 105
5 Answers5
I felt the need to make another answer because of differing conditions, which appeared in chat.
This is a known bug.
Status: In Progress (since 1/03/2014)
Importance: Medium
Bug info up-to-date as of 01/30/2017.
The workaround offered in Post 38 of said bug report works.
An easier-to-understand version:
  1. Run lsusb and get the Wacom device code. (In this example, 056a:0319) Add 0x to both strings. (With our example 0x056a and 0x0319). If your device is not on the below list, this solution may not work! Though unlikely, this may break your system. You have been warned.
  2. Open Gedit by running gksudo gedit /etc/default/grub
  3. Look for the line GRUB_CMDLINE_LINUX_DEFAULT="quiet splash".
  4. Change it to this (Replace the 0x056a and 0x0319 with whatever you got in Step 1):
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbhid.quirks=0x056a:0x0319:0x40000000"
    Save and close Gedit.
  5. Don't forget to run
    sudo update-grub
    after you change grub!!!
  6. Reboot. If it works, DO NOT GO ANY FURTHER.
  7. Open Gedit again by running gksudo gedit /usr/share/X11/xorg.conf.d/50-wacom.conf. Paste the data from this link into it and save.
  8. Reboot once again. Again, if it works, DO NOT GO ANY FURTHER!
  9. If it still doesn't work, follow the git method from this link. Please note that you need to install Git if you don't have it already: sudo apt-get install git-core.
  10. Reboot.
Steps 1-5 are confirmed to work for the following devices:
  • 056A:0318 -- Wired Bamboo Pad
  • 056A:0319 -- Wireless Bamboo Pad
Devices not on this list have not been tested and may not work. Use at your own risk! If a device not on this list worked for you, please add it to the above list.
Kaz Wolfe
  • 34,680
--- THIS ANSWER DOES NOT SOLVE THE PROBLEM! Use my above answer instead! ---
AHA!
Your problem is in this line, right here:
cp: -snip- Access denied
Try using:
sudo cp 3.7/wacom.ko /lib/modules/3.13.0-37-generic/kernel/drivers/input/tablet
Also make sure that the xf86-input-wacom package is installed. If not, use this handy link:
Install via the software center
Reboot and enjoy!
Kaz Wolfe
  • 34,680
Changing grub, as described from Whaaaaaat (point 1-5), worked for me (12.04 and 14.04), great, thanks, however only after adapting the ID from lsusb output: My example lsusb output:
Bus 002 Device 005: ID 056a:0318 Wacom Co., Ltd
this means we need to adapt the ID from:
to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbhid.quirks=0x056a:0x0318:0x40000000"
Summary: Check your lsusb wacom ID prior to change GRUB_CMDLINE_.....
It seems like this tablet's been around for a while with no sign of resolution from Ubuntu. The marked fix works well for getting basic stylus functionality going, but in some cases it does not enable the stylus button (so no right click), and it does not enable the buttons on the pad or the touchpad functionality.
A reply on the bug report claims to have gotten full functionality, including touchpad, by editing /usr/share/X11/xorg.conf.d/50-wacom.conf to add MatchIsTablet:
MatchProduct "Wacom|WACOM|Hanwang|PTK-540WL|ISD-V4"
MatchIsTablet "on"
I haven't had success with it myself but it might make a difference for others depending on configuration.
What I finally wound up doing was to create a UNetbootin Live USB Flash Drive from an older Ubuntu 14.04.1 LTS Desktop ISO which I had made back in 2013. And installed from that. In that Older Ubuntu kernel incarnation, the Wacom Bamboo Pen Tablet was still recognized. so that I could set its 'System Settings' Tablet GUI to set the Mouse Emulation Mode and Reassign the Stylus Key functions. I then still needed to implement Mouse Pointer Acceleration in order to obtain correct Tablet functioning., But that older hardware function is also disabled in newer incarnations of Ubuntu, even in 14.04.01. So, because xorg commands which are entered from 'Terminal' are not retained on reboot. I added an xset entry to Startup Applications from the ('Console' located at the Top of the Unity bar) ' xset m 6 1 ' And labeled that MouseAcceleration. (m indicates Mouse, and the first number 6 being the acceleration factor). After this and other System Settings had been completed, I then installed the Ubuntu Updates to bring the older Kernel up to speed.
Previous to this on a 14.05.5 Live USB with Persistence, I tried the steps outlined above, but no joy. Steps 1 through 5 could not be retained because sudo update-grub only returned could not write to /cow
and the ' gksudo gedit /usr/share/X11/xorg.conf.d/50-wacom.conf ' option, only returned an entry list which was already precisely the same as the referenced list.
It was at this point that I decided to go with what I wound up doing.
As a previous Windows user, what initially sold me on giving Ubuntu Linux a try to begin with, was Leo Lapport (a few years back) on his The Tech Guy radio program stating that Linux and especially Ubuntu Linux had retained Native Drivers for Older computer hardware in their Kernels. Making it possible for the disadvantaged to get some useful life out of older and outdated computers that would otherwise be junked. In that respect, its very sad to see them now stripping out so much native support for the older drivers.
