So I managed to successfully install Ubuntu and get everything working except wireless.
I do not have an Internet connection, but I can retrieve files from the Internet via use of my OS X partition.
I used b43updated.zip from this thread: No Wireless When Install 14.04 on Macbook Pro. I can see "Connect to hidden connection" and can toggle wireless, but no networks appear in the list.
Output of lspci -nn | grep 0280:
02:00.0 Network controller [0280]: Broadcom Corporation BCM4322 802.11a/b/g/n Wireless LAN controller [14e4:432b] (rev 01)
I'm also using Ubuntu MATE at this point, not Ubuntu.
I've also managed to get the Wi-Fi networks to show in the network list, but not to connect.
arcetera
  • 107
Please check here: Installing Broadcom Wireless Drivers The correct driver for your 14e4:432b device is bcmwl-kernel-source. You can retrieve it and its dependency dkms from the install DVD or USB using this method. Navigate to pool > restricted > b > bcmwl and drag and drop the deb file to your desktop. Now navigate to pool > main > d > dkms and drag and drop dkms to your desktop. Now install both with:
cd ~/Desktop
sudo dpkg -i *.deb
Load the driver:
sudo modprobe wl
Your wireless should now be working.
chili555
  • 61,330
  1. Get internet with alternative way such as ethernet or usb modem
  2. Go into the Ubuntu dash and look up Drivers
  3. Click on "Additional drivers"
  4. let it load
  5. Select the one that says broadcom and on it and install
  6. Reboot and you will have wifi
Of course this will only work, if you can arrange alternate internet connection for few minutes.
noob
  • 161
