Description of problem:
Ethernet connection gets disconnected at random apparently without any reason. I have tried the following command to restart my ethernet connection,
sudo service network-manager restart
though it never solved the issue. Every time I have to restart my system to get the connection back.
Details of my Ethernet card:
$ lspci -nnk | grep -iA2 net
06:00.0 Network controller [0280]: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) [168c:002b] (rev 01)
        Subsystem: Lenovo Device [17aa:30a1]
        Kernel driver in use: ath9k<br>
07:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 02)
        Subsystem: Lenovo Device [17aa:392e]
        Kernel driver in use: r8169
My system: Ubuntu 14.04 LTS 64bit on Lenovo ideapad z560.
OBSERVATION: It happens more frequently when I make calls in skype or hangout. It seems that heavy usage of Ethernet is causing the disconnection.
Debug steps tried so far:
I found a post Wired Network is not stable in ubuntu 13.04 (64-bit) have something similar problem description as mine but not exactly. Following the solution given in that post, I installed and tried to use an older kernel linux-image-3.5.0-27-generic. But the same problem persisted there.
At the same time I am not sure if it is a hardware related issue as this never happened with Windows 7 which I was using before. I did a lot of googling but could not find a solution except a few about older versions and bug report.
As a hint to look into dmesg [ thanks to @noleti ], I found the following:
$ dmesg -T | grep eth0
[Sat May  2 19:52:37 2015] r8169 0000:07:00.0: eth0: RTL8102e at 0xffffc90000348000, 88:ae:1d:3a:ec:ff, XID 04e00000 IRQ 41
[Sat May  2 19:52:45 2015] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[Sat May  2 19:52:51 2015] r8169 0000:07:00.0: eth0: link down
[Sat May  2 19:52:51 2015] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[Sat May  2 19:52:56 2015] r8169 0000:07:00.0: eth0: link up
[Sat May  2 19:52:56 2015] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[Sat May  2 20:09:01 2015] NETDEV WATCHDOG: eth0 (r8169): transmit queue 0 timed out
[Sat May  2 20:09:01 2015] r8169 0000:07:00.0: eth0: link up
[Sat May  2 20:09:13 2015] r8169 0000:07:00.0: eth0: link up
[Sat May  2 20:09:19 2015] r8169 0000:07:00.0: eth0: link up
[Sat May  2 20:09:31 2015] r8169 0000:07:00.0: eth0: link up
[Sat May  2 20:10:13 2015] r8169 0000:07:00.0: eth0: link up
[Sat May  2 20:10:55 2015] r8169 0000:07:00.0: eth0: link up
[Sat May  2 20:12:07 2015] r8169 0000:07:00.0: eth0: link up
[Sat May  2 20:13:49 2015] r8169 0000:07:00.0: eth0: link up
After the event as shown in dmesg output my connection is lost.
Sooraj Soman
  • 1,111
First of all, I tried to replace r8169 with r8168 which happens to be a bug for many users having Realtek Ethernet Controller, but never solved the problem, even now almost an year after posting this. I face the same problem even with the latest kernel update 4.2.0-30-generic.
Solution:
Replace the current kernel with a stable older kernel version, in my case I installed kernel version 3.2.0-83-generic manually in 14.04 LTS. Now the Ethernet connection is stable and the problem is solved.
Download the following .deb packages from 1, 2, 3, 4 and install it:
sudo dpkg -i linux-headers-3.2.0-83_3.2.0-83.120_all.deb
sudo dpkg -i linux-headers-3.2.0-83-generic_3.2.0-83.120_i386.deb
sudo dpkg -i linux-image-3.2.0-83-generic_3.2.0-83.120_i386.deb
You can change the boot order by editing GRUB_DEFAULT=0 in /etc/default/grub as given here. Then
sudo update-grub
sudo reboot
I think you can try to install other latest v3.2 kernels which too may be stable, Ex: 3.2.0-98-generic
Note: I have tested it for both 32bit and 64bit Ubuntu 14.04 LTS
Sooraj Soman
  • 1,111
May be you could try to limit the speed of the ethernet adapter ? Try:
sudo ethtool -s eth0 speed 100 duplex half
Or if this does not help, try https://unix.stackexchange.com/questions/37727/solving-ethernet-watchdog-timer-deadlocks
solsTiCe
  • 9,515
as from dmesg -T | grep eth0 output, you are using r8169 driver which has been unstable for few network cards try manually downgrading driver to r8168
hope this helps
Waqas
  • 819
