I am doing these via terminal. I am trying to install GCC package on ubuntu-14.04.2-server-i386
I encounter this problem which is similar in nature except my problem is trying to install gcc instead of build essentials.
It appears the solution is to install software-center however i encountered the same problem when I am trying to install software-center.
How do i solve this problem ???
I need to find a way to install software-center and then change the server to Main Server via terminal
Computernerd
  • 1,401
You do not need to install software-center, you need to change your /etc/apt/sources.list to include deb http://archive.ubuntu.com/ubuntu trusty main restricted Since this is a server installation you can use the editor of your choice. Nano should be installed allready. So:
sudo nano /etc/apt/sources.list
and add the line
and run
apt-get update
apt-get install gcc
muru
  • 207,228
Bruni
  • 11,099
