I have installed MariaDB from source and now I need to uninstall it. I used these commands to install it:
wget http://mirrors.hustunique.com/mariadb/mariadb-10.0.14/source/mariadb-10.0.14.tar.gz
tar -zxvf mariadb-10.0.14.tar.gz
cd mariadb-10.0.14/
apt-get install cmake
apt-get install g++ openssl libssl-dev libncurses5-dev libboost-dev bison
cmake . -DCMAKE_INSTALL_PREFIX=/usr/local/mysql \
  -DWITH_FEDERATED_STORAGE_ENGINE=1 -DWITH_SSL=system
make && make install
How do I uninstall it?
There are a few other options which might be of use:
sudo apt-get remove mariadb-server
This will remove just the mariadb-server package itself.
sudo apt-get remove --auto-remove mariadb-server
This will remove the mariadb-server package and any other dependant packages which are no longer needed.
If you also want to delete your local/config files for mariadb-server then this will work.
sudo apt-get purge --auto-remove mariadb-server
but be careful with that last one. See the disclaimer at the installion site
Col Wilson
  • 246
first stop mariadb service
sudo service mysql stop
then
sudo apt-get --purge remove "mysql*" # this will delete all database , make backup of your db's
source :: how to remove mariadb fully
-2
The easy way for this is installing the synaptic package manager by typing the following command in the terminal:
sudo apt-get install synaptic
And then open synaptic by:
sudo synaptic
Then search for the package you have installed, mariadb, and mark it for complete removal and press apply.
bolzano
  • 1,610
