I recently did a fresh install to 15.04. I downloaded and installed vmware player, but when I go to launch it, I receive a message saying "vmware workstation several modules must be compiled and loaded into the kernel."
I click install so that it can proceed, but then I get an error saying that it is "unable to start services."
Any ideas of how I can get it to work again?
Seth
  • 59,332
found here https://communities.vmware.com/thread/509225
This can be fixed by running the following steps as Root (in a terminal):
  1. log in as root (e.g. sudo -i)
  2. Enter your Root password.
  3. Enter these commands:
    curl https://pastebin.com/raw/Z1ihzbcE -o /tmp/vmnet-3.19.patch
    cd /usr/lib/vmware/modules/source
    tar -xf vmnet.tar
    cd vmnet-only
    patch -p0 -i /tmp/vmnet-3.19.patch
    mv vmnet.tar vmnet.tar.SAVED
    tar -cf vmnet.tar vmnet-only
    rm -r vmnet-only
    vmware-modconfig --console --install-all
VMware will now compile the vmnet module for Kernel 3.19. (please make sure you have DKMS installed)
Airee
  • 15
Make sure to upgrade to the latest version of VMware player before trying the patch. While I was on VMware Player 6.x the patch didn't work, but on 7.1.x it worked.
-1
This worked well for me:
For the newbies out there, This is what the commands will do by running it in terminal:
  • In the folder /usr/lib/vmware/modules/source, you have to extract the vmnet-only file from vmnet.tar and make a backup of the .tar-file.
  • Run the patch you downloaded from http://pastie.org/pastes/9934018/download before making a new vmnet.tar from the vmnet-only folder
  • Delete the vmnet-only folder and do the compiling
0x2b3bfa0
  • 9,110
  • 38
  • 55
GjB
