12
After update my system to 15.04, I have an error message at the boot: 'starting build 219'.
The bug is known, its recommend to go to console mode and enter this command:
sudo systemctl enable sddm.service -f
But when I enter this command I get an error message:
Error getting authority: Error initializing authority: Could not connect: No such file or directory (g-io-error-quark, 1)
muru
  • 207,228
Jbz797
  • 131
I had some similar errors with my system, and I found that it was an error with some fstab entries (external drives that were no longer physically connected). I just commented them out and the system booted as usual. Or you can try to reattach missing external devices.
hwong557
  • 217
You may get such an error if your display manager is not sddm.
Running the following can show which display manager you are using :
cat /etc/X11/default-display-manager
For example, if your display manager is /usr/sbin/gdm, running the following may help :
sudo systemctl enable gdm.service -f
