I've run distro upgrade from 14.04 to 15.10 with the release image. I chose "erase the disk and install Ubuntu" installation. No errors during installation and I'm able to login in normally.
Eventually I will get this message:
fsck from util-linux 2.26.2
/dev/mapper/ubuntu--vg-root: clean 194728/13557760 files, 947832/54231040 blocks
It then dumps me back to the login page. Cycle repeats and repeats, but never boots me into the desktop.
When I boot into recovery mode, I can run fsck from there, and it gives me the same clean message. However, it does give me the message:
 "Error getting authority: Error initializing authority: Could not connect: No such file or directory (g-io-error-quark, 1)
Any ideas what's going on? I've re-run install a few times and get the same thing every time.
Zanna
  • 72,312
I'll be honest, and I have no idea why this worked. I booted into recovery mode. Ran fsck. Then fixed broken packages (which downloaded 3 new packages). Resumed boot into the new image. It threw one error, uploaded the details and it's all good now.
The fsck message is probably a red herring. You are probably just seeing typical boot noise from the console because there is an issue with your display drivers preventing the X server from starting a display manager.
Glad to hear you got it fixed though. If I had to guess, one of the broken/outdated packages was a binary display driver.
I had same trouble after uninstalling a kubuntu-desktop on my ubuntu 15.10 laptop. try reinstall lightdm.
sudo apt-get install --reinstall lightdm
ttdd
