I'm wondering something. Whenever i right click on minecraft and click open with another application, i try to find Java JDK. I have installed it for minecraft itself, but i just cant find where java is on the list of other applications. Any help?
As I wrote here:
For some reason the desktop file for OpenJDK is not installed, even though this file is listed.
$ apt-file list openjdk-8-jre | grep desktop
openjdk-8-jre: /usr/share/applications/openjdk-8-java.desktop
openjdk-8-jre: /usr/share/applications/openjdk-8-policytool.desktop
$ ls -l /usr/share/applications/openjdk-8-java.desktop
ls: cannot access /usr/share/applications/openjdk-8-java.desktop: No such file or directory
$ dpkg --get-selections | grep openjdk-8
openjdk-8-jre:amd64             install
Install Java with these commands, in order to get the required entry:
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java8-installer
and then
sudo apt-get install oracle-java8-set-default
And in order to do things more easily, use the Minecraft Installer.
sudo add-apt-repository ppa:minecraft-installer-peeps/minecraft-installer
sudo apt-get update
sudo apt-get install minecraft-installer
Then run Minecraft from the Dash.
A.B.
  • 92,125
