I was trying to bind a keyboard shortcut to my script. I tried binding it to keyboard shortcut from
System Settings>Keyboard>Shortcuts>Add Shortcut
I added new shortcut and as mentioned in this link I tried to add bash /path/to/my/script in the command section of the new shortcut. The permission is right.
It runs when I run from terminal.
I tried binding it using compiz-config-settings as mentioned in the answer given by n3rd. But it did not work.
this is my script.
Pravin
  • 165
The command more doesn't seem to work.
Try changing each time it says more to cat.
How did I solve it?
I added this line after each if:
notify-send Alert No1
changing the number 1 to another number each time I used it. This showed me that the if then else statements weren't running. I then decided to change it to cat, because I use that and know it works!
notify-send
is a useful debugging tool for me. Have a look at it's man page to make it easier to use. If you can't use it, try to echo sometextNo1 > logfile.txt, and check that file.
Tim
  • 33,500
