This old bug affects me severely, I say old bug because it is very well documented in the following link: Bug report
This bug results in two things:
My on-board networking doesn't work, and trying to restart or shut-down the computer freezes the system.
So, if you read the bug report you noticed there is a fix, well I have actually successfully fixed the issue two times, but it keeps coming back after reboot, and now I can't seem to fix it.
Fix that worked:
  • Added forcedeth msi=0 msix=0 to /etc/modules
  • Added exec rmmod forcedeth directly underneath the beginning of the script section in the file /etc/init/kmod.conf (I can't find a module-init-tools.conf, is the kmod.conf the equivalent?)
  • Added modprobe forcedeth msi=0 msix=0 to /etc/rc.local
It seems like I’m very close to solving this problem that affects my machine so much, but at the same time I’m lost because I don’t understand the way the modules and the forcedeth works.
content of modprobe.d:
alsa-base.conf              blacklist-modem.conf         iwlwifi.conf
blacklist-ath_pci.conf      blacklist-oss.conf           mlx4.conf
blacklist.conf              blacklist-rare-network.conf  modesetting.conf
blacklist-firewire.conf     blacklist-watchdog.conf      vmwgfx-fbdev.conf
blacklist-framebuffer.conf  fbdev-blacklist.conf
Fabby
  • 35,017
I suggest you remove all the instances you mention above. The correct way is:
sudo -i
echo "options forcedeth msi=0 msix=0"  >  /etc/modprobe.d/forcedeth.conf
exit
Upon reboot, the parameters will be applied. Whether they fix your exact issue is another question.
chili555
  • 61,330
