This question relates to Crouton only in that Ubuntu is running under it on my Chromebook. I've installed 14.04 with xfce on an ext4-formatted SD card.
I seem to be having all kinds of problems, and no packages seem to want to install correctly. One of the packages I tried to install was Firefox, which would not install correctly through Software Center despite running it as gksu software-center per this answer. In attempting to install it from the command line, I get this input/output error (sorry for the long paste):
Preparing to unpack .../firefox_37.0.1+build1-0ubuntu0.14.04.1_amd64.deb ...
Unpacking firefox (37.0.1+build1-0ubuntu0.14.04.1) over (37.0.1+build1-0ubuntu0.14.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/firefox_37.0.1+build1-0ubuntu0.14.04.1_amd64.deb (--unpack):
 unable to create `/etc/apport/native-origins.d/firefox.dpkg-new' (while processing `./etc/apport/native-origins.d/firefox'): Input/output error
/bin/df: '/mnt/stateful_partition': No such file or directory
                                                             /bin/df: '/usr/share/oem': No such file or directory
                                 /bin/df: '/home/chronos': No such file or directory
    /bin/df: '/home/.shadow/472855b8f1a7fba3c1a1f1160e3f4f39f8236d43/mount': No such file or directory
                      /bin/df: '/home/chronos/user': No such file or directory
        /bin/df: '/home/user/472855b8f1a7fba3c1a1f1160e3f4f39f8236d43': No such file or directory
       /bin/df: '/home/chronos/u-472855b8f1a7fba3c1a1f1160e3f4f39f8236d43': No such file or directory
                     /bin/df: '/home/root/472855b8f1a7fba3c1a1f1160e3f4f39f8236d43': No such file or directory
                              /bin/df: '/run/crw': No such file or directory
        Selecting previously unselected package xul-ext-ubufox.
Preparing to unpack .../xul-ext-ubufox_3.0-0ubuntu0.14.04.1_all.deb ...
Unpacking xul-ext-ubufox (3.0-0ubuntu0.14.04.1) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for mime-support (3.54ubuntu1.1) ...
(trusty)james@localhost:~$ dmesg | tail -30
[10563.225680] EXT4-fs error (device sdb1): ext4_mb_generate_buddy:742: group 464, 22958 clusters in bitmap, 22957 in gd
    (...plus ~25 more of that error...)
[10563.247003] EXT4-fs error (device sdb1): ext4_find_dest_de:1645: inode #133094: block 532849: comm dpkg: bad entry in directory: rec_len is smaller than minimal - offset=0(0), inode=0, rec_len=0, name_len=0
[10563.248966] ecryptfs_do_create: Failure to create dentry in lower fs; rc = [-5]
[10563.248979] ecryptfs_create: Failed to create file inlower filesystem
[10564.825928] EXT4-fs error (device sdb1): ext4_mb_generate_buddy:742: group 16, 24208 clusters in bitmap, 24197 in gd
[10567.444090] EXT4-fs error (device sdb1): ext4_mb_generate_buddy:742: group 387, 17420 clusters in bitmap, 18620 in gd
The output at the bottom from dmesg was per this answer, and indicates that there are certainly some file IO errors. sdb is my SD card.
My question is this: Does this problem seem related to my installation being on an SD card? If it is a problem with the file IO, it might also help explain the problems I'm having with other packages such as dpkg: error: parsing file '/var/lib/dpkg/available' near line 0: from a corrupt file (full of garbage), and files list file for package '(package name)' is missing final newline, to name a couple. Would installing Trusty directly on my SSD potentially help with these problems?
Update, ~10 days later: I reinstalled Trusty directly on my Chromebook's internal SSD under Crouton, and have had no problems since. I believe the issues above were related to an issue with Crouton resuming after the computer has gone to sleep (see issue #288). It also may have been caused by accidentally removing the SD card without properly ejecting it.
