I am using Ubuntu 12.04 as a repo and would like to view a progress bar when using rsync from the command line. I tried the option suggested in this article (-P), but I prefer to see a progress bar and not use Grsync. I am using rsync -P source dest currently.
- 72,312
- 1,443
- 2
- 9
- 7
rsync has a --info option that can be used to not only output the current progress, but also the transfer rate and elapsed time:
--info=FLAGS fine-grained informational verbosity
The explanation of how to use it comes under the -P option in the man page:
-P The -P option is equivalent to --partial --progress. Its purpose is to
make it much easier to specify these two options for a long transfer that
may be interrupted.
There is also a --info=progress2 option that outputs statistics based on
the whole transfer, rather than individual files. Use this flag
without out‐putting a filename (e.g. avoid -v or specify --info=name0)
if you want to see how the transfer is doing without scrolling the screen
with a lot of names. (You don’t need to specify the --progress
option in order to use --info=progress2.)
So the following:
rsync -r --info=progress2 --info=name0 "$src" "$dst"
Results in the following being output and continuously updated:
18,757,542,664 100% 65.70MB/s 0:04:32 (xfr#1389, to-chk=0/1510)
Note that when the transfer starts the total number of chunks, and therefore the current progress, can change when the recursive option is used as more files are discovered for syncing
- 1,591
You can use --progress and --stats parameters.
$ rsync -avzh --progress --stats root@server:/path/to/file output_name
root@server's password:
receiving incremental file list
file
98.19M 54% 8.99MB/s 0:00:08
From man page/explainshell:
-a, --archive
-v, --verbose
-z, --compress
-h, --human-readable
--progress This option tells rsync to print information showing
the progress of the transfer. This gives a bored user something to
watch. Implies --verbose if it wasn’t already specified.
--stats This tells rsync to print a verbose set of statistics on
the file transfer, allowing you to tell how effective rsync’s
delta-transfer algorithm is for your data.
- 17,371
- 1,356
- 8
- 14
How about this?
rsync_param="-av"
rsync "$rsync_param" a/ b |\
pv -lep -s $(rsync "$rsync_param"n a/ b | awk 'NF' | wc -l)
$rsync_paramAvoids double input of parameters
$(rsync "$rsync_param"n a/ b | awk 'NF' | wc -l)Determines the number of steps to complete.
a/ ba/is the sourcebis the target
- 92,125
Yeah, do what Jon said: use the --info=progress2 option. But, what do I do if my version of rsync is too old and doesn't support this option? Answer: upgrade rsync!
Here's how to build rsync from source on Ubuntu
(tested on Ubuntu 16.04)
Download latest version of rsync: https://download.samba.org/pub/rsync/src/. Ex: "rsync-3.1.3.tar.gz". Save it in a directory WITH NO SPACES AT ALL to ensure it builds right.
In your folder explorer, right-click it and go to "Extract Here".
Enter the extracted folder (ex: "rsync-3.1.3")
Right-click the screen in your folder manager and go to "Open in Terminal." Alternatively, do steps 2 through 4 manually on the command line. Ultimately you just need to be
cded into this extracted directory containing thersyncsource code.Check current version of
rsync. Make note of this so you can see later it actually got updated.rsync --versionInstall necessary tools:
sudo apt update sudo apt install yodlBuild:
./configure make sudo make installEnsure it was updated:
rsync --version
Sample output:
$ rsync --version
rsync version 3.1.3 protocol version 31
Copyright (C) 1996-2018 by Andrew Tridgell, Wayne Davison, and others.
Web site: http://rsync.samba.org/
Capabilities:
64-bit files, 64-bit inums, 64-bit timestamps, 64-bit long ints,
socketpairs, hardlinks, symlinks, IPv6, batchfiles, inplace,
append, no ACLs, xattrs, iconv, symtimes, prealloc
rsync comes with ABSOLUTELY NO WARRANTY. This is free software, and you
are welcome to redistribute it under certain conditions. See the GNU
General Public Licence for details.
Search the man pages for "progress2". You'll now have access to the
--info=progress2option:man rsync
...then press / key and type progress2; press Enter to search for it; press n for the 'n'ext match until you find the entry you're looking for:
There is also a
--info=progress2option that outputs statistics based on the whole transfer, rather than individual files. Use this flag without outputting a filename (e.g. avoid-vor specify--info=name0) if you want to see how the transfer is doing without scrolling the screen with a lot of names. (You don’t need to specify the--progressoption in order to use--info=progress2.)
Also see:
- [my answer] "How to use rsync": https://superuser.com/questions/1271882/convert-ntfs-partition-to-ext4-how-to-copy-the-data/1464264#1464264
Partial References:
- 11,502
- 14
- 97
- 142
This finally worked:
rsync "$rsync_param" -a --prune-empty-dirs --exclude "*.iso" rsync://archive.ubuntu.com/ubuntu/indices/ /repo/ubuntu/indices | pv -lep -s $(rsync "$rsync_param"n rsync://archive.ubuntu.com/indices/ /repo/ubuntu/indices | awk 'NF' | wc -l)
- 92,125
- 1,443
- 2
- 9
- 7
Something I find useful is using a tqdm like this:
Like @ostrokach said, you can install it either by
pip install tqdm
or
sudo apt install python3-tqdm
Set the params:
SRC=a/
DST=b
PARAMS=-av
And invoke:
rsync ${PARAMS} ${SRC} ${DST} | tqdm --null --unit-scale --total=$(rsync ${PARAMS}n ${SRC} ${DST} | wc -l)
This will show overall progress counting files (actually - counting lines).
If you want to see the files being copied, you can omit the --null option from tqdm.
- 2,225
