I'm having a wifi issue on my laptop that I have no idea how to solve.
My laptop runs in dual-boot Windows 8.1/Ubuntu 14.04: whenever I'm using windows, all the connections run with no problem; on ubuntu, instead, wifi connections work for a couple minutes after start-up, and then they stop working until I reboot. Wired connections work fine.
I found this question, probably relevant to my case. Refering to this answer I saw that in my case Power Management:on, so I tried running sudo iwconfig wlan0 power off, but I get this error
Error for wireless request "Set Power Management" (8B2C) :
SET failed on device wlan0 ; Operation not supported.
Probably useful infos:
##### lspci #############################
02:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter [10ec:b723]
Subsystem: Lenovo Device [17aa:b736]
Kernel driver in use: rtl8723be
##### iwconfig ##########################
wlan0     IEEE 802.11bgn  ESSID:off/any
      Mode:Managed  Access Point: Not-Associated   Tx-Power=off
      Retry  long limit:7   RTS thr=2347 B   Fragment thr:off
      Power Management:on
Thanks in advance for help!
EDIT: It seems Power Management is not the cause of the problem, as turning it off didn't solve it.
Matteo V
  • 103
I suspect that power management is not manipulable by iwconfig because the driver has available several parameters related to power saving; from modinfo:
parm:           swlps:bool
parm:           swenc:using hardware crypto (default 0 [hardware])
 (bool)
parm:           ips:using no link power save (default 1 is open)
 (bool)
parm:           fwlps:using linked fw control power save (default 1 is open)
 (bool)
I suggest you try this; from a terminal:
sudo -i
echo "options rtl8723be fwlps=0 swlps=0"  >  /etc/modprobe.d/rtl8723be.conf
exit
Reboot and test.
chili555
  • 61,330
It seems I found a solution to the problem, using
echo "options rtl8723be fwlps=0 swlps=0" | sudo tee /etc/modprobe.d/rtl8723be.conf
More on this on this forum post. Wifi has been working for a couple hours now with no problems.
Matteo V
  • 103
