I recently installed ubuntu 14.04 LTS along side Win8.1 on my new laptop. Wireless connection worked well for a day and then it started disconnecting whenever I downloaded something or restarted/shut down the pc. The connection can only be brought back again if I switched the router on and off.
I tried this (turning off Power Management):
https://askubuntu.com/a/537375/433874
It connected me to network but whenever I restart the pc the Power Management is on again and I have to switch the router on and off all over again. I don't think its a problem with my router cuz my old laptop had ubuntu 12.04 with win7 and there was no problem.
This too did not work:
https://askubuntu.com/a/609180/433874
And when I run this for buggy N:
modprobe -r iwlwifi && modprobe iwlwifi 11n_disable=1
It gives the following:
rmmod: ERROR: ../libkmod/libkmod-module.c:769 kmod_module_remove_module() could not remove 'iwlmvm': Operation not permitted
rmmod: ERROR: could not remove module iwlmvm: Operation not permitted
rmmod: ERROR: Module iwlwifi is in use by: iwlmvm
modprobe: FATAL: Error running remove command for iwlwifi
When iwconfig :
eth0 no wireless extensions.
wlan0 IEEE 802.11abgn ESSID:"TP-LINK_A1B2F8"
Mode:Managed Frequency:2.412 GHz Access Point: A0:F3:C1:A1:B2:F8
Bit Rate=40.5 Mb/s Tx-Power=22 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=44/70 Signal level=-66 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:205 Invalid misc:90 Missed beacon:0
lo no wireless extensions.
Any help?
