I recently set up Ubuntu on a new Dell XPS 13 (9343), and I've been having a bit of trouble with the trackpad. It cannot right click. Here's what I've tried so far:
Checking xinput: Output of xinput -list was:
$ xinput -list
⎡ Virtual core pointer                      id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ ELAN Touchscreen                          id=10   [slave  pointer  (2)]
⎜   ↳ Mouseemu virtual mouse                    id=16   [slave  pointer  (2)]
⎜   ↳ DLL0665:01 06CB:76AD UNKNOWN              id=12   [slave  pointer  (2)]
⎜   ↳ PS/2 Synaptics TouchPad                   id=14   [slave  pointer  (2)]
⎣ Virtual core keyboard                     id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Power Button                              id=8    [slave  keyboard (3)]
    ↳ Sleep Button                              id=9    [slave  keyboard (3)]
    ↳ Integrated_Webcam_HD                      id=11   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=13   [slave  keyboard (3)]
    ↳ Mouseemu virtual keyboard                 id=15   [slave  keyboard (3)]
    ↳ Dell WMI hotkeys                          id=17   [slave  keyboard (3)]
After checking all of the possibilities, I determined that DLL0665:01 06CB:76AD UNKNOWN was the only one that when disabled, caused the trackpad to stop working. None of the others had any effect.
Naturally, I ran xinput --test 12, and I got the following results:
- Regardless of which button (left or right) I pressed, button press 1 and button release 1 were called.
- If I pressed the trackpad in two places, at slightly different times (talking a few dozen milliseconds, but it could not be at the same time), then it would output the button press 3 and the button release 3 that I would expect from a right click. These clicks could be anywhere on the trackpad as long as the timing was correct.
It is also worth noting that xdotool still works correctly, and that things like right click worked fine on Windows.
If any of you could help me figure out what is going on, that would be wonderful. Thank you.
