I am able to use custom composer key sequence like described here: How can I add a custom compose key sequence?
Using this method needs to export GTK_IM_MODULE="xim". But doing so will disable IBus Anthy input for me.
Is there a way to have the sweetness of both, customized composer key sequences AND IBus Anthy input?
During research I have read that composer key sequences in Gnome are hardcoded in gtk+-2.10.7/gtk/gtkimcontextsimple.c, so editing and recompiling might work, although I do not want to resort to such a method yet...
Edit: I don't need Anthy working with the custom composer keys, basically I want to have two input Methods: Japanese Anthy and EN_UK (with the composer)
I have made the same observation. IBus, which is enabled by default in Ubuntu, has some built-in compose table rules, but at the same time it seems to disable the functionality provided by libx11.
From some sources it's said that ~/.XCompose is recognized together with uim. So a possible solution for you (untested) might be to install and enable the uim IM framework and start using uim-anthy instead of ibus-anthy.
Edit:
I was curious, so I tested. uim seems to work. Can't tell how convenient it is to use Anthy with uim instead of ibus, though.
