I've searched a method to change the brightness of my laptop display. I saw one article on this forum and followed the instruction like below (under the line) written by Serge (user name).
I ran command line sudo nano brightness and when editor popped up I typed 100 and hit the new. However, the brightness didn't get changed even though I restarted the laptop. So I gave up changing setting.
Then, I want to delete the setting, file or folder that I created(?) using nano which I typed 100 in it. How can I do this?
Now we can edit brightness file to actually change screen brightness. We will need some text editor command. I prefer using command line text editor nano. So I would do
It will ask you for your password. Enter it, and you will see another screen. Look at where your cursoris, right after the number. That's what I mean when I said "don't hit enter".
This file has to have only that one line, no other. You can use left / right keys to move cursor, and backspace or del keys to delete old number, and then type new. Remember, that you can only go from whatever number was in max_brightness file to 0.
When you wrote new number, press Ctrl+X, it will ask if you want to "Save modified buffer". Press Y. Then it will asks what name of the file to write. Just press enter, we do not want to change name of this file. Done. At this point your brightness should change.
The file "brightness" is on a pseudo file system used by the kernel.
See Why are these directories called file systems?
The general location is /sys/class/backlight/ , although the exact location varies by graphics card.
Example - /sys/class/backlight/intel_backlight/brightness
You can not delete these files.
There are many ways to adjust brightness, but of them I would not use nano.
See How to change LCD brightness from command line (or via script)?
Personally I a script and invoke the script as sudo or you can simply
echo 10 | sudo tee /sys/class/backlight/.../brightness
The "..." varies with video card and driver, you will need to adjust the path an necessary.
For example, using an Intel GMA500 (my favorite card ;p)
  • Poulsbo driver (closed source) path is /sys/class/backlight/psblvds/brightness
  • Open source (kernel) driver path is /sys/class/backlight/acpi_video0/brightness
Note: depending on the card there may be a fix, see also https://wiki.ubuntu.com/Kernel/Debugging/Backlight
Panther
  • 104,528
