So basically, I run ubuntu 14.04 and I can't install packages. I ran
sudo apt-get -f install
and the terminal gave me this
the-administrator@Tower-Of-Power:~$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libcdr-0.0-0 libcmis-0.4-4 libmspub-0.0-0 liborcus-0.6-0 libvisio-0.0-0
libwps-0.2-2
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
libreoffice-common
Suggested packages:
libreoffice-style-breeze libreoffice-style-crystal
libreoffice-style-hicontrast libreoffice-style-oxygen libreoffice-style-sifr
libreoffice-style-tango
The following NEW packages will be installed:
libreoffice-common
0 upgraded, 1 newly installed, 0 to remove and 13 not upgraded.
18 not fully installed or removed.
Need to get 0 B/22.0 MB of archives.
After this operation, 82.3 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 284027 files and directories currently installed.)
Preparing to unpack .../libreoffice-common_1%3a4.4.2~rc2-0ubuntu1~trusty1_all.deb ...
Unpacking libreoffice-common (1:4.4.2~rc2-0ubuntu1~trusty1) ...
dpkg: error processing archive /var/cache/apt/archives/libreoffice-common_1%3a4.4.2~rc2-0ubuntu1~trusty1_all.deb (--unpack):
trying to overwrite '/usr/bin/soffice', which is also in package openoffice-debian-menus 4.1.1-9775
rmdir: failed to remove ‘/var/lib/libreoffice/share/prereg/’: No such file or directory
rmdir: failed to remove ‘/var/lib/libreoffice/share/’: No such file or directory
rmdir: failed to remove ‘/var/lib/libreoffice/program/’: No such file or directory
rmdir: failed to remove ‘/var/lib/libreoffice’: No such file or directory
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Processing triggers for gnome-icon-theme (3.10.0-0ubuntu2) ...
Processing triggers for hicolor-icon-theme (0.13-1) ...
Processing triggers for gnome-menus (3.10.1-0ubuntu2) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for mime-support (3.54ubuntu1.1) ...
Processing triggers for shared-mime-info (1.2-0ubuntu3) ...
Any advice?
