I cannot seem to figure out what exactly is needed to allow the maximum number of file descriptors to be raised permanently for all users.
/etc/security/limits.conf:
root hard nofile 1500000
root soft nofile 1000000
root hard nproc 15000
root soft nproc 10000
* hard nofile 1500000
* soft nofile 1000000
* hard nproc 15000
* soft nproc 10000
I have placed the following in the /etc/pam.d/common-session:
session required pam_limits.so
After a reboot, logging in as any user and issuing ulimit -n resulted in 1024.
After that, I tried requiring pam_limits.so into every file under /etc/pam.d. Rebooted. Logged in. No such luck.
If I issue the command ulimit -n 1000000, then check, the limit is set as expected. So, I placed @reboot ulimit -n 1000000 into crontab -e. Rebooted. Logged in. No luck.
I checked /etc/ssh/sshd_config and PAM is enabled.
I have tried setting the limits on every reboot with:
/sbin/sysctl -w fs.file-max=1000000
/sbin/sysctl -p
No luck.
I have a server that has a ton of concurrent traffic, and need those limits that high, because it takes the server a very long time to clear out file descriptors. What do I have to do in order to permanently raise the file descriptor limit?
