24
when i open Lutris and then LOL client , this happening. And game never work good. I tried many things but never can change the open file limit. How can fix this ?
Waiting on children
Waiting on children
eventfd: Too many open files
esync: write: Bad file descriptor
also there is my limits info
~$ ulimit -a
core file size          (blocks, -c) 0
data seg size           (kbytes, -d) unlimited
scheduling priority             (-e) 0
file size               (blocks, -f) unlimited
pending signals                 (-i) 15106
max locked memory       (kbytes, -l) 16384
max memory size         (kbytes, -m) unlimited
open files                      (-n) 1024
pipe size            (512 bytes, -p) 8
POSIX message queues     (bytes, -q) 819200
real-time priority              (-r) 0
stack size              (kbytes, -s) 8192
cpu time               (seconds, -t) unlimited
max user processes              (-u) 15106
virtual memory          (kbytes, -v) unlimited
file locks                      (-x) unlimited
Doug Smythies
  • 16,146
When the "Too Many Open Files" error message is written to the logs, it indicates that all available file handles for the process have been used (this includes sockets as well).
In a majority of cases, this is the result of file handles being leaked by some part of the application. ulimit is a command in Unix/Linux which allows to set system limits for all properties. In your case, you need to increase the maximum number of open files to a large number (e.g. 1000000):
ulimit -n 1000000
or
sysctl -w fs.file-max=1000000
and /etc/security/limits.conf or /etc/sysctl.conf change:
fs.file-max = 1000000
To determine if the number of open files is growing over a period of time, issue lsof to report the open files against a PID on a periodic basis. For example:
lsof -p [PID] -r [interval in seconds, 1800 for 30 minutes] > lsof.out
This is especially useful if you don't have access to the lsof command:
ls -al /proc/PID/fd
Guidelines for setting ulimits
Carolus
  • 600
I think, there are different cases why this might happen:
  1. System wide limit (Run cat /proc/sys/fs/file-max to see the limit, for me it's 9223372036854775807)
  2. Max user instances (Run cat /proc/sys/fs/inotify/max_user_instances: used to be 128)
  3. Hard user limit (Run ulimit -nH: 1048576)
  4. Soft user limit (Run ulimit -nS: used to be 1024)
The system wide rule can be adjusted by putting
fs.file-max = 9223372036854775807
into /etc/sysctl.conf. This value was no issue for me.
For me, this value was too low. To fix it, add or edit this line again in /etc/sysctl.conf
fs.inotify.max_user_instances = 1024
3. & 4. Hard or soft user limit
My soft user limit was too low, too. To fix that, open /etc/security/limits.conf (as root) and add this line:
<username>             soft    nofile 100000
(Replace <username> with your username, or * for all users)
The hard user limit can be set by replacing soft with hard in the line above. Of course, you can have multiple rules for hard & soft limit or different users.
Putting things into effect
Maybe a logout and logging back in is enough for the changes to be picked up, but I just restarted the system to be sure.
iGEL
  • 496
Run
less /proc/PID/limits
to check the actual Soft Limit of Max open files. If you set up ulimits but the actual number is still low - review how you launch the process. E.g., systemd takes over the ulimits, and you should use explicit settings, better at the process level, to ensure your program gets the runtime limits it needs.
SVUser
  • 121
On an Apple Silicon mac, the only solution that ended up working for me was
sudo sysctl kern.maxfiles=100000 kern.maxfilesperproc=100000
Akaisteph7
  • 111
