I have this problem since I do a fresh install Ubuntu 14.10 (previously I don't have this problem in 14.04). I tried to follow any instruction available in internet but it doesn't change anything so I have no idea what to do now. Sreenshot
Here is the output of dmesg | grep -i bluetooth:
[   22.521992] Bluetooth: Core ver 2.19
[   22.522014] Bluetooth: HCI device and connection manager initialized
[   22.522022] Bluetooth: HCI socket layer initialized
[   22.522024] Bluetooth: L2CAP socket layer initialized
[   22.522036] Bluetooth: SCO socket layer initialized
[   22.573800] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   22.573804] Bluetooth: BNEP filters: protocol multicast
[   22.573812] Bluetooth: BNEP socket layer initialized
Output of lsusb:
Bus 002 Device 003: ID 174f:114f Syntek
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 105b:e065
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Output of lsmod | grep bluetooth:
bluetooth             446190  7 bnep
6lowpan_iphc           18702  1 bluetooth
Output of rfkill list all
0: ideapad_wlan: Wireless LAN
    Soft blocked: no
    Hard blocked: no
1: ideapad_bluetooth: Bluetooth
    Soft blocked: no
    Hard blocked: no
2: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
3: brcmwl-0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
Not supported by the Utopic kernel yet, but it can be made to work
sudo apt-get install build-essential linux-headers-generic
wget https://www.dropbox.com/s/uocd0xqaprm4yvi/bluetooth.utopic.tar.gz
tar -zxf bluetooth.utopic.tar.gz
cd bluetooth
cp /boot/config-$(uname -r) .config
cp /usr/src/linux-headers-$(uname -r)/Module.symvers Module.symvers
make -C /lib/modules/$(uname -r)/build M=$PWD modules
sudo cp btusb.ko /lib/modules/$(uname -r)/kernel/drivers/bluetooth/
wget https://www.dropbox.com/s/f503f6r686riiow/fw-105b_e065.hcd
sudo cp fw-105b_e065.hcd /lib/firmware/brcm/BCM43142A0-105b-e065.hcd
echo btusb | sudo tee -a /etc/modules && sudo modprobe btusb
Then check dmesg | grep -i firmware to see if there are any firmware errors and post errors
After a kernel update you will need to recompile the module
cd bluetooth
make -C /lib/modules/$(uname -r)/build M=$PWD clean
sudo modprobe -r btusb
sudo modprobe btusb
and bluetooth should work in a new 3.16 series kernel
Jeremy31
  • 13,293
